Thread: 02 monte SS wil not start!! Please help!
Results 1 to 4 of 4
  1. #1 02 monte SS wil not start!! Please help!
    Oct 2012
    waldorf, MD
    2 Years ago the car ran but would die at a stop light intermittently. I checked
    the code and it called out high voltage MAFS. So I replaced it and it didn't fix
    a thing. I let the car sit for two years and periodically I would start it up
    and let it run for a while. Today a friend of mine came over and we went to
    start it and nothing I mean nothing. The battery is perfect i.e. new. Here is
    what I noted as odd the radio doesn’t turn on, the door locks don’t work. In the
    DIC there is battery, security, SES that alternate and illuminate.
    So far.... I have conducted a CASE learn and in the procedure the security light on
    the DIC is supposed to turn off after ten minutes or so of having the key in the
    on/start position. It says ten minutes or so.... I did it over and over and
    started over and still can’t get the security light to secure on the
    DIC.
    I'm completely lost and need help! I can’t afford to take it to the
    dealer. It's a 2002 monte ss.
  2. #2 Re: 02 monte SS wil not start!! Please help!
    St. Louis
    Start by removing both battery cables and cleaning the battery terminals and the cables. Then make sure they are tight after reinstall and see what you get.
    How "new" is this battery? Was it new 2 years ago, or new as in bought it last week?
  3. #3 Re: 02 monte SS wil not start!! Please help!
    On the relearn. The DIC goes through a pattern of security, check engine, blah, blah, back to security, check eng... and so forth. When you stop seeing security in the rotation, that's the 10 minutes.
  4. #4 Re: 02 monte SS wil not start!! Please help!
    Oct 2012
    waldorf, MD
    I checked the battery and the connections all is perfect, battery is brand new. The key is the original pass key. The case learn will not take the security light won't stop flashing. Any other suggestions.
  1. monte z34
    By DoubleBlown in forum Introductions/Noob Questions
    Last Post: 04-19-2011, 10:23 AM
  2. 05 GP, 03 Monte SS
    By 2WBodys in forum Introductions/Noob Questions
    Last Post: 02-17-2011, 05:27 PM
  3. Monte!
    By Pure2sin in forum Introductions/Noob Questions
    Last Post: 08-06-2010, 12:08 AM
  4. The start of a on going thread of my Monte.
    By 7801MonteMan in forum Visual/Body Modifications
    Last Post: 04-19-2010, 03:47 PM
  5. monte
    By roxettelook in forum Chevrolet Monte Carlo
    Last Post: 03-14-2010, 01:46 AM
