Thread: Trans shifts are off after TPS replaced
Results 1 to 9 of 9
  1. #1 Trans shifts are off after TPS replaced
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    I replace the TPS today on my 97 GT, and after that was done i took it for a ride and the shift points were way off. It did not shift into OD at all, shifted out of first at 26MPH also. When I installed the TPS, i did have to move the throttle to get the mounting holes to line up, but it idled fine. I did put the old one back on and still the same Issue...Any ideas?
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  2. #2 Re: Trans shifts are off after TPS replaced
    Bump a vacuum line soemwhere?
    Being that your 4T60e trans is vacuum assisted.
  3. #3 Re: Trans shifts are off after TPS replaced
    Jul 2011
    Michigan
    Yeah, I played with the vacuum lines too. Didn't help at all. I just unplugged the battery to reset the computer...i'll hook it back up in the morning before work to see if it helped at all.
  4. #4 Re: Trans shifts are off after TPS replaced
    Look at the TPS on a scanner for 0-100% or ...tell us why you replaced it.
    Because TPS will directly effect/screw with your shifts.
  5. #5 Re: Trans shifts are off after TPS replaced
    PA
    yeah, you need to make sure it is reading from 0 to 100, like bill mentioned. It if is off, it will screw things up.
    2001 GSE
  6. #6 Re: Trans shifts are off after TPS replaced
    Jul 2011
    Michigan
    it threw a code at autozone so I replaced it. And when You first started it and put it in gear, it would almost die out.
  7. #7 Re: Trans shifts are off after TPS replaced
    SWPA
    TPS has to be properly adjusted. I had to adjust the TPS on my cousin's Stealth because it was screwing with his shifts and it only needed moved literally less than 1/16th of an inch.
  8. #8 Re: Trans shifts are off after TPS replaced
    Jul 2011
    Michigan
    How do you go about adjusting it? I hear on these cars they are not adjustable. Is it done by moving the Idle screw on the TB?
  9. #9 Re: Trans shifts are off after TPS replaced
    no.
    Move the TPS sensor so that the TPS % reads 0-100 and the TPS voltage reads between .40-4.0 at each end of the spectrum.
  1. trans ticking noise? Shifts fine...
    By m17davis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-23-2012, 07:00 PM
  2. 98 GTP, Trans lossing 4th gear sometimes, shifts hard and slips into 3rd.
    By shawnooohhh in forum General Tech Discussion
    Last Post: 02-11-2012, 10:44 AM
  3. Replaced trans filter and look what i found
    By 99GPGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-19-2010, 04:38 PM
  4. Replaced trans, tapshift not working
    By 04GTPCOMPG in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-11-2010, 10:45 AM
  5. Replaced pass. halfshaft - what did I screw up in the trans???
    By GTPrix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-25-2008, 12:00 AM
