Thread: Intake temp vs coolant temp.
Results 1 to 14 of 14
Threaded View
  1. #3 Re: Intake temp vs coolant temp.
    GT Level Member Tony Mendez's Avatar
    Aug 2012
    Somerset WI
    Pretty rare to see MAF displayed in lbs/minute.
    If you have the ability to monitor for and graph misfire data, I would look there to see what cylinder(s) may not be contributing during your hesitation. If you are seeing a pattern for 1 or more cylinders, focus your efforts at determining what is causing the issue. As far as your IAT and ECT, they appear to be ok but all should be checked under the same conditions as your hesitation. Duplicate the situation and problem first. Monitor your scan data during the event and record it. Most times your problem will show up in the recorded data.
    Also curious as to the vacuum reading. 29.92 in of vacuum is what is referred to as "Max Achievable Vacuum" and isn't something we see in automotive vacuum readings. Typically you are looking for 15-22 inches with the needle or reading holding steady on a properly running engine.
  1. Coolant Temp Gauge
    By travis328 in forum General Tech Discussion
    Last Post: 02-13-2012, 09:31 AM
  2. Coolent temp Goes to regular temp and drops down?
    By Lukesgrandprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-11-2012, 08:11 AM
  3. Coolant Temp Isuue
    By Codester in forum General Tech Discussion
    Last Post: 10-21-2011, 09:28 PM
  4. coolant temp
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 07-08-2010, 01:21 AM
  5. Normal coolant temp?
    By nboylie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-07-2009, 08:46 PM
