Thread: Intake temp vs coolant temp.
Results 1 to 14 of 14
  1. #1 Intake temp vs coolant temp.
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    2001 gt 97,000
    I have been having hesitation problems off and on at certain speeds. it tends to happen on warm days.
    My question is when I hook up my scanner, I'm checking the different parameters. So Its 60 degrees out and car is in garage. Intake temp says 70 degrees which makes since. But coolant temp says 81 degrees. I start the car and within a minute the coolant temp goes up 90 a second later goes 108..... Is that normal?
    Car had been sitting for 11 plus hours so should have been completely cool.
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    What does it say when the car is fully warmed up? And why do you have 29in of vac?
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  3. #3 Re: Intake temp vs coolant temp.
    GT Level Member Tony Mendez's Avatar
    Aug 2012
    Somerset WI
    Pretty rare to see MAF displayed in lbs/minute.
    If you have the ability to monitor for and graph misfire data, I would look there to see what cylinder(s) may not be contributing during your hesitation. If you are seeing a pattern for 1 or more cylinders, focus your efforts at determining what is causing the issue. As far as your IAT and ECT, they appear to be ok but all should be checked under the same conditions as your hesitation. Duplicate the situation and problem first. Monitor your scan data during the event and record it. Most times your problem will show up in the recorded data.
    Also curious as to the vacuum reading. 29.92 in of vacuum is what is referred to as "Max Achievable Vacuum" and isn't something we see in automotive vacuum readings. Typically you are looking for 15-22 inches with the needle or reading holding steady on a properly running engine.
  4. #4 Re: Intake temp vs coolant temp.
    If your thermostat is working correctly your car should warm up pretty fast. Go start your car for 30 seconds then grab the exhaust manifold.
  5. #5 Re: Intake temp vs coolant temp.
    Aug 2012
    Chicago
    The fuel trims are from car being idle.
    Reading, while driving at 25 mph....... temp intake 77 degrees....coolant 190 degrees..... map reading 21 inHg.....maf reading is 2.5
    It only does the stumble/hesitation periodically, at take off and again at around 20 mph
    Intake temp vs coolant temp. Attached Images
  6. #6 Re: Intake temp vs coolant temp.
    It says MAP, which is manifold absolute pressure. Which should also be measured in kPa.
    You could easily have issues with the MAF being dirty/out of spec, old plugs/wires, weak coils, dirty fuel injectors, weak fuel pump, clogged fuel filter etc.
    It could also be transmission related as well.
  7. #7 Re: Intake temp vs coolant temp.
    Aug 2012
    Chicago
    That's true... I did check fuel pressure its about 45 psi. I cleaned throttle and have not been able to find any intake leaks. Tinkering with the maf wires didn't help either.
    When I unplug the maf sensor (which is a fairly new aftermarket unit) it doesn't hesitate and it has better pick up.
    But I know that unplugging the maf doesn't necessarily mean the maf is bad, because unplugging it masks other components that could be the problem.
    In the next week I'm going to try to do a tune up, and clean sea-foam the injectors. And see what happens.
  8. #8 Re: Intake temp vs coolant temp.
    45 psi under what conditions?
    It should be 45 PSI with 5 psi of vacuum which is half the vacuum your car should produce at idle.
    Check fuel pressure with the vacuum connector off, it should be ~50.8 psi.
    If unplugging the maf is generally what we consider "the maf test" which implies the MAF is bad. I agree its not an absolute, but its probable that it is at fault.
    I'd suggest hitting up a junk yard and picking up a few MAFs and trying those out. Or cleaning the one you have. Better yet, warranty it.
  9. #9 Re: Intake temp vs coolant temp.
    Aug 2012
    Chicago
    45 psi at idle ..you mean check it with with vacuum to the pressure regulator off?
    I thought about grabbing a few from the junkyard, but they take them off the cars and want 80 bucks a piece for them. I may buy a used ac delco maf and take the one I have back
    I bout a cheaper aftermarket maf at start up it would rev up on its own for a few seconds.. and periodically hesitate/stumble.I sent it back.
    I then bought a new car-done unit (Its only a few weeks old.) It helped with the start up problem but hesitates/stumbles just the same as the other unit. I will probably return it and get a used ac delco and hope it works ..three's a charm right? lol
    They want 80 bucks for the maf at the junkyards near me.
  10. #10 Re: Intake temp vs coolant temp.
    at idle it should be around 19-21 in Hg MAP, and as a result, fuel pressure should be 40-42 depending on vacuum and accuracy of gauge.
    IIRC, the best way to check fuel pressure is at idle with the vacuum line off, should jump right to 50-52 psi.
    That price on used MAFs is ridiculous. Do they come with year+ warranty at that price?
    I believe I have two or three sets working factory MAF/IAC/TPS for this reason.
  11. #11 Re: Intake temp vs coolant temp.
    Aug 2012
    Chicago
    OK Thanks, I will use those specs and see what the pump reads.
    And no they have at most 45-60 day warranties on the used mafs.
    ebay has them for about 40 bucks 30 day warranty. I may get one from there.
  12. #12 Re: Intake temp vs coolant temp.
    Put up a WTB for used MAF in the classifieds.
  13. #13 Re: Intake temp vs coolant temp.
    Aug 2012
    Chicago
    OK I just did thanks.
  14. #14 Re: Intake temp vs coolant temp.
    Wouldn't suggest shelling more than 20-30 shipped out for one.
  1. Coolant Temp Gauge
    By travis328 in forum General Tech Discussion
    Last Post: 02-13-2012, 09:31 AM
  2. Coolent temp Goes to regular temp and drops down?
    By Lukesgrandprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-11-2012, 08:11 AM
  3. Coolant Temp Isuue
    By Codester in forum General Tech Discussion
    Last Post: 10-21-2011, 09:28 PM
  4. coolant temp
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 07-08-2010, 01:21 AM
  5. Normal coolant temp?
    By nboylie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-07-2009, 08:46 PM
