A little shade tree mechanic trick. Get a long screw drive, place the tip on each injector and put your ear on the handle. the injector or possible lifter that is making the nooise will be louder than the rest. You should hear a slight ticking from the injectors through the screw driver because of them cycling, but if one is loud enough for you to hear, it will be unnoticable with the screw driver.
