Thread: How to take out stock air intake
Results 1 to 18 of 18
98GTPnoob How to take out stock air... 09-06-2012, 04:28 PM
Explicit_Spade Re: How to take out stock air... 09-06-2012, 04:30 PM
winterstorm Re: How to take out stock air... 09-06-2012, 04:42 PM
98GTPnoob Re: How to take out stock air... 09-15-2012, 01:40 PM
nik12937 Re: How to take out stock air... 09-06-2012, 05:22 PM
blueguy Re: How to take out stock air... 09-07-2012, 12:10 AM
dbextreme Re: How to take out stock air... 09-15-2012, 02:10 PM
BrendanMurphy Re: How to take out stock air... 09-15-2012, 11:45 PM
winterstorm Re: How to take out stock air... 09-15-2012, 11:48 PM
dazedandconfused This thought crossed my mind... 09-16-2012, 12:40 AM
BrendanMurphy Re: How to take out stock air... 09-16-2012, 12:42 AM
stealthee Re: How to take out stock air... 09-16-2012, 07:43 AM
dazedandconfused You're a failure my friend.... 09-16-2012, 10:11 AM
BrendanMurphy Re: How to take out stock air... 09-17-2012, 01:42 AM
Logan541 Re: How to take out stock air... 09-16-2012, 11:14 AM
stealthee Re: How to take out stock air... 09-17-2012, 07:41 AM
dazedandconfused I don't care what science... 09-17-2012, 09:59 AM
Pontiac Man Re: How to take out stock air... 09-17-2012, 10:05 AM
  1. #1 How to take out stock air intake
    Sep 2012
    Ohio
    Im fairly new to my gtp and I don't wanna f*** things up
    Can some one make a how to" for taking out a stock intake for 98 gtp
  2. #2 Re: How to take out stock air intake
    Omaha, NE
    Its a pretty self explanatory process once you look at it...
  3. #3 Re: How to take out stock air intake
    GTP Level Member winterstorm's Avatar
    Jun 2012
    Connecticut
    dude cmon, thats like one of the easiest things to do. you take the bar thats above it off so you can remove the box. then you undo the box as if you were gunna take the filter out. then rip the box out. that simple.
    2005 Grand Prix GT
    Corsa Sport Catback, Thrasher Shift Kit, Custom Open Cone Intake, Spyder Chrome CCFL Halo Projector Headlights, CG LED Tail Lights, Pioneer DEH-33HD stereo unit, Alpine SPR-60C 2 way 6 1/2's, Kicker KS 6x9's
  4. #4 Re: How to take out stock air intake
    Sep 2012
    Ohio
    Quote Originally Posted by winterstorm View Post
    I tryed removing the bar above it and the bolts just keep turning... I figured there's a nut under the bar? But there's no room for to fit a hand? I'm confused
  5. #5 Re: How to take out stock air intake
    Pennsylvania, USA
    Your PCM sits inside/at the bottom of the box as well, either buy a tray online or do what most people do and zip tie it or something similar so it is secure.
  6. #6 Re: How to take out stock air intake
    Never seen someone try to torch it.
    Do that and video it.
  7. #7 Re: How to take out stock air intake
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Your bolts sound stripped... There are two bolts on your radiator support and one bolt up on your strut tower (if you need pics let me know). IF your bolts just freely turn, try to wedge a large screwdriver under the "bar" and try to pry it up as you turn to see if you can get unstripped threads to catch. I have cross threaded one of mine, I can get it out but I can't tighten it down..
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  8. #8 Re: How to take out stock air intake
    GT Level Member BrendanMurphy's Avatar
    Jan 2012
    Keswick, Ontario
    I took the airbox out without removing that bar just rip on it, it will come out
  9. #9 Re: How to take out stock air intake
    Jun 2012
    Connecticut
    yeah your bolts sound stripped there are no nuts underneath. if you cant get them out its not a huge deal you still can get the airbox out, itll just be somewhat of a pain in the butt haha
    2005 Grand Prix GT
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    Quote Originally Posted by blueguy91 View Post
    This thought crossed my mind when I saw the title.
    Step 1. Douse area with gasoline, or diesel fuel.
    Step 2. Light said area.
    Step 3. Stand back and drink a beverage of choice.
    Step 4. Call fire dept or insurance company. Choice is yours
    Step 5. Video steps 1-3.
    Easy peezy lemon squeezy.
    Sent from my iPhail
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  11. #11 Re: How to take out stock air intake
    Jan 2012
    Keswick, Ontario
    Quote Originally Posted by dazedandconfused View Post
    Sent from my iPhail
    Your logic has failed. Throwing a match or lighter on diesel fuel will not do anything.
  12. #12 Re: How to take out stock air intake
    SWPA
    I've lit diesel with a lighter before. It burns, just doesn't go woosh like gasoline does.
    Sep 2011
    bedford, Pa
    Quote Originally Posted by BrendanMurphy View Post
    You're a failure my friend. Diesel fuel is a terrific fire starter.
    Sent from my iPhail
  14. #14 Re: How to take out stock air intake
    Jan 2012
    Keswick, Ontario
    Sent from my iPhail
    Disel fuel is lignite by heat not flame or spark. It requires a high temperature to light it. At least this is what science says, if i am wrong than forgive me
  15. #15 Re: How to take out stock air intake
    Feb 2010
    TN
    when you get the box opened and the filter out you will find 3 bolts holding it in I believe they are 10 mm
  16. #16 Re: How to take out stock air intake
    SWPA
    Diesel is flammable. An open flame can light it. It takes a much higher temperature to light oil on fire, but it burns too.
    Sep 2011
    bedford, Pa
    I don't care what science says. Hold a match to diesel fuel and prepare to be amazed.
    Sent from my iPhail
  18. #18 Re: How to take out stock air intake
    GT Level Member Pontiac Man's Avatar
    Sep 2011
    Decorah IA
  1. Replies: 81
    Last Post: 02-14-2013, 02:57 AM
  2. Stock Intake Box with filter
    By dmack976 in forum Wanted To Buy - Parts
    Last Post: 02-06-2012, 04:03 PM
  3. Stock intake tube?
    By 99GTPzilla in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2010, 08:27 PM
