Thread: MAF Sensor Question?
Results 1 to 3 of 3
  1. #1 MAF Sensor Question?
    Sep 2012
    Nebraska
    I have a 2000 Pontiac Grand Prix GTP that is running rough and lost gas mileage.
    I have put a code reader on it and it said it was no voltage at the MAF sensor. Put another one in the car and it doesn't run any better? Someone had said one time they found a blown fuse, I pulled every fuse in the car and all are fine! I checked to see if I had voltage at the Connector to the MAF sensor and I do?
    I could really use some tips on what else I might have going on??
    Thanks,
    Brian
  2. #2 Re: MAF Sensor Question?
    check the wires from the plug to the maf, if you see any cracks in the wires you need a new pig tail.
    with the car off, un plug the maf, then start it, if it runs better unplugged then something is wrong with the maf or wires to it.
  3. #3 Re: MAF Sensor Question?
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    check the IGN 1 fuse in the under hood box it should be a 10 amp or 15 amp mini fuse
  1. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  2. Question about a MAF sensor.
    By thenervemann in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2009, 08:45 PM
  3. Sensor question,,,,,,I think
    By the955iman in forum General Tech Discussion
    Last Post: 04-22-2009, 04:14 PM
  4. MAF sensor question
    By Black2000GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-12-2009, 07:06 PM
  5. o2 sensor question
    By TJs97 in forum General Tech Discussion
    Last Post: 06-22-2008, 09:26 PM
