Thread: Can't figure out knocking noise
Results 1 to 2 of 2
  1. #1 Can't figure out knocking noise
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    So my fiero (2.5 4 cylinder) had a bad knock when i bought it. You could hear it over the exhaust which was totally broken in half. So it was pretty loud. Anyways i didnt really care at the time because i planned to swap a 284 Getrag and a 3800 into it. Well no times have change and i have a few shortcomings in my wallet so i decided just to tear the motor apart and fix it to put back in and sell. Well when i tore it apart i was expecting a rod bearing to be spun but there wasnt. The bearings did just fall out tho so obviously theyd been hot but other than that looked good. The main bearings also look good. The pistons dont have much wear on the skirts at all and the cylinders are smooth and there is not ring ridge at all. There was a bit of play between the crank psproket and camgear but i don't think that would make a rod knock noise. The only 2 things i did find where 3 broken top piston rings and a bunch of metal chunks on the screen of the pick-up tube. So any ideas on what the knocking could be.
    I went NA when a whore left -$300 in my bank account.
  2. #2 Re: Can't figure out knocking noise
    Piston slap on the junky 4 cyl chevy motors.
  1. Trying to figure out the noise coming from front wheels 04 GTP
    By Bandit1228 in forum General Tech Discussion
    Last Post: 08-30-2012, 06:56 AM
  2. Knocking noise in rear?
    By BlueGXP in forum General Tech Discussion
    Last Post: 10-17-2011, 08:38 PM
  3. can someone help me figure out what this noise is
    By taman86 in forum General Tech Discussion
    Last Post: 02-25-2011, 01:14 AM
  4. Knocking Noise While Braking
    By jonrk7 in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2010, 02:14 PM
  5. knocking noise. HELP
    By GMtuner29 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2010, 07:39 PM
