Thread: Throttle Position Sensor or Vac Leak????
Results 1 to 6 of 6
  1. #1 Throttle Position Sensor or Vac Leak????
    Sep 2012
    Calgary
    I tested the voltage at the TPS with throttle full open and got 4.1V whereas I read somewhere it should go up to 4.8V. I also read one guy replaced his TPS 3 times before finding out it was a vacuum leak. How do you determine a vacuum leak and can fix it myself?
    Meegwetch!!!
  2. #2 Re: Throttle Position Sensor or Vac Leak????
    Are you getting a code?
  3. #3 Re: Throttle Position Sensor or Vac Leak????
    And what kind of car do you have?
  4. #4 Re: Throttle Position Sensor or Vac Leak????
    Sep 2012
    Calgary
    i havent taken it for a code check but from all the dsecriptions ive seen this seems quite common behaviour for TPS problems. its a 2002 GT, 3.8L.
    How could it be a vac leak? in the air system or fuel system?
  5. #5 Re: Throttle Position Sensor or Vac Leak????
    Wichita
    Carb cleaner
  6. #6 Re: Throttle Position Sensor or Vac Leak????
    SE Level Member destroyer85golf's Avatar
    Aug 2012
    Hillsdale Illinois
    Engine Vacuum Leaks read this page it will explain why a vaccuum leak will cause rough idle. I myslef have in the past been very quick to blame the TPS. Till i learned that most times it is a vaccuum leak instead.
    2000 GTP daytona 500
  1. throttle position sensor trouble
    By shart in forum General Tech Discussion
    Last Post: 10-17-2011, 11:33 AM
  2. Throttle Position Sensor
    By apierce1289 in forum General Tech Discussion
    Last Post: 06-07-2011, 09:00 PM
  3. Throttle Position Sensor Optimization
    By silverstreak in forum How To Write-Ups/Tech Tips
    Last Post: 12-25-2010, 03:06 PM
  4. throttle position sensor
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-25-2010, 11:16 AM
  5. THrottle position sensor
    By xsvtank in forum General Tech Discussion
    Last Post: 11-27-2010, 07:17 PM
