Thread: Engine fusebox wires melted
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #1
    Dec 2010
    DMV
    When the hood closes it closes on top
    Of the fuse box wire and thats where the amp wire was connected at also.
  2. #2 Re: Engine fusebox wires melted
    Houston
    I know but mine is doesn't even come close to touching the top of the fuse box. Unless your amp wire was sticking up and it shorted out before the fuse, that's the only way I can see the main battery cable getting fried. If the amp line shorted after the fuse, the fuse would pop and end of story.
    Dec 2010
    DMV
    We have a winner.
    Fuse is AFTER that wire so I'm guessing it grounded right there in that spot. Which In turn heated up the battery cable. Which in turn started smoking and which in turn gave my hood that nice burn mark. Well it could have been worse. So should I b ok to make it home tonight? It's like a 20 min drive home.
  4. #4 Re: Engine fusebox wires melted
    Just make sure you get that fixed soon. Wouldn't want that shorting out again.
    Dec 2010
    DMV
    Yea I removed the amp wire from that location. Well is just plain unhooked. So I should buy new battery cables correct? Hard to install?
    Dec 2010
    DMV
    Replaces all cables
    Everything is good now
  7. #7 Re: Engine fusebox wires melted
    Houston
    Replaces all cables
  8. #8 Re: Engine fusebox wires melted
    Did you put your fuse closer to the battery? Like right at the connection is where you want it.
    Dec 2010
    DMV
    Well my amp wire isn't connected straight to my battery. It's connected
    At the fuse box connection.
  1. Put a 2001 engine in a 1998 grand prix..help!!! Wires smoking
    By Djstanley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2012, 01:46 PM
  2. new fusebox cover and cross braces
    By beckys2000gt in forum Visual/Body Modifications
    Last Post: 06-26-2010, 10:12 AM
  3. new engine cover, braces n fusebox cover
    Last Post: 05-27-2010, 09:40 AM
  4. Custom Fusebox & Underhood Lining
    By Spartan GL in forum Visual/Body Modifications
    Last Post: 01-20-2010, 12:16 AM
  5. sparkplug melted
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 04-12-2009, 05:22 PM
