Thread: head gasket?
Results 1 to 10 of 10
  1. #1 head gasket?
    SE Level Member Mikefisher's Avatar
    Winkler,Manitoba,Canada
    I was told that there is 2 different head gaskets for my 99 Gt.One is nicely priced but the other one is $400(Can).They said it depends on when the motor was made.I need to fix mine and want to make sure that I am getting the right one.Thanks in advance !
    Pike---- Family of rapacious,malevolent,razor-toothed freshwater game fish that will strike instantly and violenty at just about any lure you decide not to try...
    http://s43.photobucket.com/albums/e381/mikefisher99/
  2. #2 Re: head gasket?
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    I spent around 35-40 for a set for head gasket.
    There is a set around 350 that has all the gaskets:
    head, blower, valve cover, header, all exhaust gaskets and a crap load of o rings.
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  3. #3 Re: head gasket?
    Is there going to be any thing that I should really look for when I ripin this damn thing apart? Would like to do it right once and not f*ck something up,you know what I'am sayin ?
  4. #4 Re: head gasket?
    I live here. UR LOSN's Avatar
    Rockford, IL
    just take your time. bag and label the bolts about where they came from so they go back n the proper location, and take notes.....or follow the service manual.
    take your time, make sure the sealing surfaces are clean! Everything is pretty straight forward, and is VERY HARD to f*ck anything up.
    EDIT: torque specs!!! follow them!
  5. #5 Re: head gasket?
    thanks for the info.Just started on ripping her apart.my fingers are crossed.
  6. #6 Re: head gasket?
    Rockford, IL
    well if you do get stuck on anything, feel free to post up. Good luck! and remember you can do it!
  7. #7 Re: head gasket?
    ok one question.I now have all of the intake parts off.All of the gaskets so far are all junk.Now should I go down to the heads to see if it is leaking there too.I am ready to push this damn thing into the lake already.
  8. #8 Re: head gasket?
    Bastard Reptile's Avatar
    Kansas City, MO
    Is there any reason in particular that you think you may need head gaskets?
  9. #9 Re: head gasket?
    well I dont know for sure if the leaking is just with the intake gaskets or not.But I dont want to take the heads off if I dont need to.If I dont have to go and buy more parts the better.I am on a very tight budget right now.but if I have to ,so be it.
  10. #10 Re: head gasket?
    Kansas City, MO
    Head gaskets rarely go out. Besides, if you were to take the heads off, you'll have to go and get new head bolts.
  1. Oil Pan Gasket
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2009, 10:03 PM
  2. Possible Head Gasket?
    By msmenne17 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-12-2008, 10:44 PM
  3. VC gasket issue?
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2008, 06:50 PM
  4. Oil Pan Gasket Replacement
    By Metallistar in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-19-2008, 01:18 PM
  5. Head Gasket Company
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2008, 04:32 PM
