Thread: Breaking in a new engine, have question
Results 1 to 20 of 29
  1. #1 Breaking in a new engine, have question
    GT Level Member SleeperGS's Avatar
    Dec 2010
    Cincinnati, Ohio
    New bearings, rods, rings, the whole works. Going to run 'el cheepo' oil for the first 500 miles to allow rings and everything to seat, and change the filter. Repeat for another 500 and then put castrol gtx semi-synthetic in it. Car has a 3800 tune in it now. I have added ported heads/exhaust and sx1 cam. All NEW sensors. Will the car run long enough and safetly with that tune? Will it even start for that matter. The reason why I am asking, is because I dont want to buy a new computer just so I can drive it to columbus where INTENSE is(i live in Cincinnati, 2 hour drive) just to have it dyno'ed for another $300. I dont want to just trailer it up there without letting the motor break in properly; having said that, I would like to make sure that there are no problems/leaks etc, before I take it to them and look like an idiot and have them be the ones to start it for the the first time and find a leak or something. Plus I want it broke in with a 1000 miles or so before I have it dynoed. Im going to run a 3.4 until I get a 1000 miles on it. Any thought, as always, are greatly apprecitated. I cant wait to feel and hear teh cam heads and all the work that has went into this.
    Kevin
  2. #2 Re: Breaking in a new engine, have question
    Ohio
    id put a bigger pulley on for the time being. then put the 3.4 on when you go to dyno it. why dont you call and ask john what the best thing to do would be?
  3. #3 Re: Breaking in a new engine, have question
    Apr 2009
    Fort Worth TX
    ^^ X2 with the bigger pulley.
    You shouldn't risk knock or detonation on a fresh rebuild until it's broken in.
  4. #4 Re: Breaking in a new engine, have question
    Ohio
    take that stupid charger belt off
    if you're too lazy to take off the pulley that is lol
  5. #5 Re: Breaking in a new engine, have question
    Dec 2010
    Cincinnati, Ohio
    I have a 3.8 pulley, will the car start okay the way it is now? and be safe... just for the break in. I'm not running at the track racing
  6. #6 Re: Breaking in a new engine, have question
    Dec 2010
    Cincinnati, Ohio
    Or the dyno
    Quincy, Mass
    You'll be ok with the stock tune, you'll be taking it easy anyways for the brake in. Do you have a scanner or scan gauge to keep an eye on things?
    You'd probably be fine with a 3.6 with those flow mods but if you have the 3.8 toss it on there.
    No more GP 04 Impala SS Indy:
  8. #8 Re: Breaking in a new engine, have question
    Might wanna break it in on break-in oil if you wanna go pick some up.
  9. #9 Re: Breaking in a new engine, have question
    Dec 2010
    Cincinnati, Ohio
    I'm actually using cheap advanced auto parts or oil, for the first 1000 miles and then I am using Castrol
  10. #10 Re: Breaking in a new engine, have question
    Apr 2009
    Fort Worth TX
    I run my engines on Penzoil mineral based and a Bosch filter for 100 miles and then go directly to Mobil 1 synthetic and filter.
  11. #11 Re: Breaking in a new engine, have question
    Dec 2010
    Cincinnati, Ohio
    I use castrol GTX semi, i have had luck with it and its easy to find anywhere. I will use the old tune, and the 3.8 for the first 1000 miles or so, then I will just drive it to Intense instead of trailering it. Will this throw any codes?
  12. #12 Re: Breaking in a new engine, have question
    Florida
    I would go ahead and make sure the 3.8" pulley is on the car, until you get ready to get it tuned. For the first few hundred miles, I wouldn't run the s/c belt, so that you won't see any boost. Also, why run "el cheapo oil" when you just spent that much getting the engine built? I'd go ahead and grab some break in oil, drive the 200-300 miles on that, then swap out to whatever oil you prefer.
  13. #13 Re: Breaking in a new engine, have question
    Dec 2010
    Cincinnati, Ohio
    I guess I could do that
    Quincy, Mass
    I usually use what ever oil and filter is on sale for the first 500 miles or so then change it to mobile 1 now. However I've never had rebuilt engine to break in, if I did I would use break in oil.
  15. #15 Re: Breaking in a new engine, have question
    when growing up we always had a saying, after a rebuild it was either go or blow, so just nail it!
    of course we didn't have a pcm to tune, you tune it yourself with a timing light and re jet the carb as needed, but you get the point.
  16. #16 Re: Breaking in a new engine, have question
    Dec 2010
    Cincinnati, Ohio
    advances oil was on sale with a a/c delco filter.
  17. #17 Re: Breaking in a new engine, have question
    Dec 2010
    Cincinnati, Ohio
    I may pick up some lucas break in oil to put in from the get go. It has zzdp in it for flat tappet cams, but since ours is a full roller motor, it wont hurt it.
  18. #18 Re: Breaking in a new engine, have question
    This.
    We put a new motor in my buddys S10, let it idle for a min to get the oil around and just hammered on it. Revved it to the moon a couple times to make sure its all working, sure did smoke up the shop but everything worked great. Once he got it on the road he did the same thing, just beat on it because if its going to blow up it will.
  19. #19 Re: Breaking in a new engine, have question
    Dec 2010
    Cincinnati, Ohio
    I have to much money to do that lol, but i will add the break in oil with zzdp, let it idle at about 1500-2500 rpms for about a half hour or so, then drive it for a 1000 or so, then get it up to intense. Then off to Edgewater
  20. #20 Re: Breaking in a new engine, have question
    This.
    there's nothing like the smell of assembly lube out the tail pipes in the morning lol
  1. Breaking Bad
    By Scottydoggs in forum Off Topic Discussion
    Last Post: 09-30-2013, 06:24 PM
  2. breaking bad
    By z3r0 in forum The Rant Forum
    Last Post: 11-12-2011, 02:46 PM
  3. uh oh breaking in cam
    By Justin48 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2010, 03:57 PM
  4. anyone breaking axles?
    By 99prixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-26-2009, 03:41 PM
  5. breaking in a glove.
    By boosting98 in forum Off Topic Discussion
    Last Post: 04-30-2009, 06:23 PM
