Thread: vacumn leak help
Results 1 to 18 of 18
  1. #1 vacumn leak help
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    alright ive been hunting down a vacumn leak its a small leak to small to throw a code but big enough to make my LTFT 16.4 at idle i have yet to take cab cleaner to the vacumn lines to find the leak i just did a visual inspection everything looks good except the BBV this looks to be a problem
    how do i check if its the BBV its self?
    the car is a 99 L67 with 176k miles on it and im only making 5psi of boost
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
    Quincy, Mass
    Just replace that bad vac line with a new piece of vac line
    No more GP 04 Impala SS Indy:
  3. #3 Re: vacumn leak help
    i would cut the old line, like a slice with a sharp razor knife right at the end where it goes over the plastic vac tree. if you pull and try to twist it, well those things break easy.
  4. #4 Re: vacumn leak help
    Oct 2011
    Michigan
    ok but that looks like a problem right? and i know i need to replace it but that doesnt look like vac line it seems more like a rubber house?
    thanks scotty ill just cut it down the center
  5. #5 Re: vacumn leak help
    May 2008
    staten island,NY
    Be careful with that vacuum tee it will break. You can use regular vac line for the bbv. The replacement tee is $20 from the dealer, might as well pick one up
  6. #6 Re: vacumn leak help
    Oct 2011
    Michigan
    i think i can get the line off without breaking it
  7. #7 Re: vacumn leak help
    Oct 2011
    Michigan
    that line does not look like regular vac line
  8. #8 Re: vacumn leak help
    its just fat, still a vac hose, take a piece with you to the store and match it up.
  9. #9 Re: vacumn leak help
    May 2008
    staten island,NY
    When my car was blown I used a regular piece of line and it was fine
  10. #10 Re: vacumn leak help
    May 2008
    staten island,NY
    Get rid of that crappy gm plastic lines too that go under the blower and use vacline I'm sure that is contributing to the vac leak
  11. #11 Re: vacumn leak help
    Oct 2011
    Michigan
    i hope not there sooooooo much vac line on this engine i dont wanna go though all of that
    will do scotty!
  12. #12 Re: vacumn leak help
    to replace all the vac lines really isn't that bad, if you really look close they just kinda make a loop around the engine. just a bunch of stop and goes..lol
    if you look through some members rides, some guys have colored vac hose, makes it easy to see where the new stuff is.
  13. #13 Re: vacumn leak help
    Oct 2011
    Michigan
    we will see i guess ill keep you all posted in my search for the leak
  14. #14 Re: vacumn leak help
    That one isn't causing you an issue. It's funny how you took a pic, posted the pic, asked the question. In under 2 minutes you could have started the car, sprayed TB cleaner and found the actual leak that you have.
    Just saying..posting is great, solving issues though..thats where it's at.
  15. #15 Re: vacumn leak help
    Oct 2011
    Michigan
    bill i was out of carb clean yesterday! anyways bill is right sprayed it with carb clan and no dice this line is not the issue where else should i check? or should i just spray everyline? what im asking is there any other known problem areas that could be causing my leak
  16. #16 Re: vacumn leak help
    Spray where the
    TB meets the charger
    PCV cover is bolted to charger
    Where that vacuum manifold on top of the charger
    the booster connects to the hose
    along the base of the SC
    Under the SC snout at the vac line
  17. #17 Re: vacumn leak help
    Oct 2011
    Michigan
    alright thanks bill ill check those spots when the rain lets up, besides carb clean and watching for rpm spikes what other ways can i hunt down this vacumn leak? any tricks you all know of?
  18. #18 Re: vacumn leak help
    Yes..you can hope for miracles. Or..just follow the cheap easy advice already given.
  1. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  2. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  5. oil leak on 3.4 dohc. Not that oil leak.
    By 67GTO in forum General Tech Discussion
    Last Post: 06-14-2010, 11:52 AM
