Thread: No MIL light
Results 1 to 20 of 29
  1. #1 No MIL light
    Aug 2012
    Oklahoma
    Howdy; Just recently bought a 2000 Grand Prix GTP. It runs perfectly, but I noticed the radio light was out and some of the DIC lights were out too. Fixed the radio, and used some #24 lamps to repair the DIC lights. Funny, the TRAC Off light bulb was broken, as if someone removed the dash trim, removed the DIC faceplate, and used pliers to bust the bulb. Well, after I repaired all the bulbs, I see that the TRAC light stays on, constantly, as long as the ignition is on. I ran codes, and got this: P0650 MIL Control Circuit Malfunction, and P0446 EVAP Emission Control System Vent Circuit Circuit Malfunction. After that, I discovered that the MIL light does not come on, nor does the ABS light. Even when first turning on the ignition. The car runs great though. Any advice about this would be appreciated.
  2. #2 Re: No MIL light
    Ohio
    uhh evap could be a stored (history) code or pending.
    and you may need a new instrument cluster with that mil malfunction one...maybe im not for sure
  3. #3 Re: No MIL light
    Assuming you've checked the bulbs on them?
  4. #4 Re: No MIL light
    Aug 2012
    Oklahoma
    Gotta do that, check them bulbs. After what I found with the DIC, no tellin'. I just discovered the issue a little while ago. Is ther a way to do it, without pulling the cluster? Somewhere at a harness plug?
  5. #5 Re: No MIL light
    Apr 2009
    Fort Worth TX
    The P0650 may be due to someone rupturing the SES bulb...sneaky buggers.
  6. #6 Re: No MIL light
    Aug 2012
    Oklahoma
    Could be . . . the previous owner or the evil used car dealer . . . .need to know If I can ohm them out without having to pull it apart
  7. #7 Re: No MIL light
    Pull dash trim. Cluster is 4 7mm bolts. One or two connectors on back of it.
  8. #8 Re: No MIL light
    Aug 2012
    Oklahoma
    Darn . . . I just put that dash trim back on
  9. #9 Re: No MIL light
    It's not going to fight..lol
  10. #10 Re: No MIL light
    Aug 2012
    Oklahoma
    Well, there I was, removing screws with my head up my ***, removing those nice silver torx screws, then I realize that the screws only hold on the clear plastic cluster lens So I put those screws back in and remove the REAL instrument cluster screws. Got the cluster out, pleasantly surprised by the nice long pony tail attached to the back. You could almost drive down the road, and let wifey (back seat driver) have at the gauges . . . . .
    Damn Evil no-good used care dealers! (well, to be honest, he could've been bamboozled too) The ABS light was gone, as well ans the MIL light and Perf light. Is there a part number for these? They are about the same size as the DIC lamps, but have gray bases and the bulb is physically a little skinnier. Maybe it's a lower amp bulb.
    So, what I'm looking at, is a TRAC light that was burning. along with ABS light on. So that tells me that I either need a new ABS module or a new hub or two; is that correct?
  11. #11 Re: No MIL light
    Apr 2009
    Fort Worth TX
    I think what they did is illegal.
  12. #12 Re: No MIL light
    Houston
    They're just 194 twist ins.
  13. #13 Re: No MIL light
    Aug 2012
    Oklahoma
    Could be, but there's no way to prove if it was the used car dealer or one of the two previous owners. Anyways, whatever it needs, I reckon I'll fix it.
  14. #14 Re: No MIL light
    Aug 2012
    Oklahoma
    They look a little small to me
  15. #15 Re: No MIL light
    Apr 2009
    Fort Worth TX
    If they were smart they would have removed the bulbs, blew them with high voltage and reinstalled. You could then say "they must have blown". What a bunch of dumba$$es. I would call them with your findings.
  16. #16 Re: No MIL light
    Aug 2012
    Oklahoma
    These are a bit smaller that 194's. The 194 work in the larger 1/2" sockets also present in the cluster, but what I need are the 3/8" ones, and they take a smaller bulb. I looked on the bay, and they sell some, with suggested lamp sizes: 17 18 27 37 58 70 73 74 79 85 86 206 207 286 306 307 308 406 407 2721 WHAT TH . . .? that's quite a selection! I'll have to figure out which one is the proper one for this application.
  17. #17 Re: No MIL light
    Houston
    #73/74's are replacements for 194's. I got these, they are T1.5's (73/74). They fit in the DIC and I replaced a burnt out bulb in the cluster. But now that I think about it, I think there were a couple different sizes back there. T1.5 LED Twist Lock Lamp Specifications
  18. #18 Re: No MIL light
    Aug 2012
    Oklahoma
  19. #19 Re: No MIL light
    Aug 2012
    Oklahoma
  20. #20 Re: No MIL light
    Houston
    Quote Originally Posted by JLR View Post
    .75 would be larger than the 194's (.5)
  1. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  2. decisions on tail light tint, third brake light and reverse bar done
    By jteske88 in forum Visual/Body Modifications
    Last Post: 06-05-2012, 05:42 AM
  3. Replies: 1
    Last Post: 02-14-2012, 05:03 PM
  4. Service Vehicle light, ABS light and intermittent stalling
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2010, 10:33 AM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
