Thread: No MIL light
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: No MIL light
    Houston
    Not sure, it looks like you'll have to remove the current bulbs from the base and see if those will fit in the base.
  2. #22 Re: No MIL light
    Houston
    Quote Originally Posted by JLR View Post
    .75 would be larger than the 194's (.5)
  3. #23 Re: No MIL light
    Aug 2012
    Oklahoma
    Well, I think I'll order those LED jobs and give 'em a try. They don't cost much. They'll outlast the car, and they use less current. 90ma vs. 17ma
  4. #24 Re: No MIL light
    Houston
    I would pull a bulb and run to a local parts store and match it up with what they have.
  5. #25 Re: No MIL light
    Apr 2009
    Fort Worth TX
  6. #26 Re: No MIL light
    Aug 2012
    Oklahoma
    In the electrical field, "T" means tubular, and the number is diameter in 1/8" increments. That's for flourescent lamps anyways. Maybe this is something similar. I also read the the 194 is 3.25. I reckon the wedge base is the same. My eyes tell me that this cluster bulb is a little smaller that the ones I put in the DIC yesterday, which were 24's from O'Reilly's. But I have to order some sockets too.
  7. #27 Re: No MIL light
    Aug 2012
    Oklahoma
    Good advice, if i was in a hurry, but this is my son's car and he can cry 'bout it for a few days while I try out those LED's. With the LED, current is a lot less so that's not a factor, smaller and less heat so those factors are ruled out. They fit in the same wedge base. But the main issue is: What to do about the ABS/TRAC OFF light problem . . . . . .
  8. #28 Re: No MIL light
    Houston
    Mine did that and they had to replace the EBCM. But was under warranty so it was free.
  9. #29 Re: No MIL light
    Aug 2012
    Oklahoma
    I saw an outfit on the web that sells rebuilt ones for about 65 plus a core charge. I'll have to go that route maybe.
  1. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  2. decisions on tail light tint, third brake light and reverse bar done
    By jteske88 in forum Visual/Body Modifications
    Last Post: 06-05-2012, 05:42 AM
  3. Replies: 1
    Last Post: 02-14-2012, 05:03 PM
  4. Service Vehicle light, ABS light and intermittent stalling
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2010, 10:33 AM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
