Thread: Car sputters when trying to boost
Results 1 to 20 of 41
Threaded View
Beelzeboul Car sputters when trying to... 08-19-2012, 10:17 PM
PokerBlakeB Re: Vaccum leak cpled with... 08-19-2012, 10:41 PM
BillBoost37 Re: Vaccum leak cpled with... 08-20-2012, 07:14 AM
Beelzeboul Re: Vaccum leak cpled with... 08-20-2012, 11:26 AM
BillBoost37 Re: Vaccum leak cpled with... 08-20-2012, 11:36 AM
Beelzeboul Re: Vaccum leak cpled with... 08-20-2012, 12:24 PM
dsmuts Re: Vaccum leak cpled with... 08-22-2012, 07:11 AM
BillBoost37 Re: Vaccum leak cpled with... 08-20-2012, 12:30 PM
Beelzeboul Re: Vaccum leak cpled with... 08-20-2012, 05:37 PM
BillBoost37 Re: Vaccum leak cpled with... 08-21-2012, 07:21 AM
Beelzeboul Re: Vaccum leak cpled with... 08-21-2012, 07:24 AM
BillBoost37 Re: Vaccum leak cpled with... 08-21-2012, 07:32 AM
Beelzeboul Re: Vaccum leak cpled with... 08-21-2012, 08:22 AM
Beelzeboul Re: Vaccum leak cpled with... 08-21-2012, 08:58 AM
BillBoost37 Re: Vaccum leak cpled with... 08-21-2012, 09:20 AM
Beelzeboul Re: Vaccum leak cpled with... 08-21-2012, 11:14 AM
Beelzeboul Re: Vaccum leak cpled with... 08-21-2012, 03:51 PM
Beelzeboul Re: Vaccum leak cpled with... 08-21-2012, 06:13 PM
Scottydoggs Re: Vaccum leak cpled with... 08-21-2012, 06:22 PM
BillBoost37 Re: Vaccum leak cpled with... 08-22-2012, 06:47 AM
BillBoost37 Re: Vaccum leak cpled with... 08-22-2012, 07:13 AM
dsmuts Re: Vaccum leak cpled with... 08-22-2012, 07:37 AM
BillBoost37 Re: Vaccum leak cpled with... 08-22-2012, 07:41 AM
dsmuts Re: Vaccum leak cpled with... 08-22-2012, 07:47 AM
Beelzeboul Re: Vaccum leak cpled with... 08-24-2012, 02:21 PM
dsmuts Re: Vac Leak/coolant light... 08-24-2012, 03:02 PM
Scottydoggs Re: Vac Leak/coolant light... 08-24-2012, 03:05 PM
Beelzeboul Re: Vac Leak/coolant light... 08-24-2012, 05:56 PM
dsmuts Re: Vac Leak/coolant light... 08-24-2012, 06:58 PM
Scottydoggs Re: Vac Leak/coolant light... 08-24-2012, 07:06 PM
Beelzeboul Re: Vac Leak/coolant light... 08-24-2012, 09:52 PM
Beelzeboul Re: Vac Leak/coolant light... 08-25-2012, 05:28 PM
Beelzeboul Re: Car sputters when trying... 08-25-2012, 06:35 PM
dsmuts Re: Car sputters when trying... 08-25-2012, 07:48 PM
Beelzeboul Re: Car sputters when trying... 08-26-2012, 01:39 AM
dsmuts Re: Car sputters when trying... 08-26-2012, 07:17 AM
Beelzeboul Re: Car sputters when trying... 08-26-2012, 04:18 PM
Scottydoggs Re: Car sputters when trying... 08-26-2012, 04:27 PM
matt5112 Re: Car sputters when trying... 08-26-2012, 04:37 PM
Scottydoggs Re: Car sputters when trying... 08-26-2012, 04:39 PM
Beelzeboul Re: Car sputters when trying... 08-26-2012, 06:31 PM
  1. #1 Car sputters when trying to boost
    GT Level Member Beelzeboul's Avatar
    Racine
    I recently checked my LTFT and FFDP had said based on reading I had a vacuum leak I had a very bad leak after reinstalling a rebuilt supercharger at the TB that shot coolant out my intake and later burned white smoke for about 3 minutes. everything was fine but after installing headers I realized the idle was rough and WOT was even rougher I definitely can identify the sound of the leak after hearing one now and know it is coming from around my driverside. Even though I just replaced this gasket I think the spit of coolant it ate before being remounted took it's tool this is based soley on the vacuum leak LTFTs coupled with an intermitent coolant light even though my reservoir is full suggesting air bubbles in the system.<br>
    <br>
    Planning on chasing the leak with some starting fluid and making sure its coming from where I believe and than replacing gasket<br>
    <br>
    if anybody know any other likely culprits I could plan on checking if it isn't my TB gasket would be appreciated<br>
    <br>
    Thanx
    I'm sorry officer I didnt know I couldn't do that
  1. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  5. Huge vaccum leak at the PCV tee...
    By alacran in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-16-2008, 04:27 PM
