Thread: Car sputters when trying to boost
Results 1 to 20 of 41
Threaded View
  1. #9 Re: Vaccum leak cpled with Intermitent coolant light
    GT Level Member Beelzeboul's Avatar
    Racine
    so my LTFT's seem to be back in order peaking at about 7 after letting off the throttle and dropping to -2/4 as I open up
    still only reading -10psi boost at idle
    also when I went WOT I had the engine throw me a code for a misfire in cylinder 3 just replaced all my plugs to one heat range cooler for the pulley
    probably shouldnt be messing with WOT till its tuned for them was my assumption but I'm thinking ill replace the wires anyway unless that would be extreme
    in either case would the low psi at idle suggest a blown SC or LIM or UIM.
    in my search for leak I went around all of the sc gasket and no increase in idle produced
    I'm sorry officer I didnt know I couldn't do that
  1. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  5. Huge vaccum leak at the PCV tee...
    By alacran in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-16-2008, 04:27 PM
