so I swapped my wires was still getting the misfire via same plug and different wire so I swapped plug with cylinder 5 and i'm not getting the ses code anymore... Still get some bogging when opening throttle up but it sounds alot cleaner. after examining spark plugs none had any black on them suggesting a rich ratio and both were in good condition
I think on my next trip to the JY imma have to pocket an injector as thats the only thing I could imagine having damaged while doing my SC swap and would produce an erratic misfire like im getting . if on my next run I end up getting the same code
Would that suggest my injector is bad?
is there anything else I should check before grabbing an injector?
