Thread: Fuse Numbers??
Results 1 to 6 of 6
  1. #1 Fuse Numbers??
    Aug 2012
    United States
    Can someone tell me the number sequence (or which are the #18 and #27 fuses) in a 1998 grand prix - the fuses in the car above the pass floorboard, not the under the hood fuses I found those.
    Trying to reset the duel climate control...blowing hot on pass side after battery change
  2. #2 Re: Fuse Numbers??
    One thread per topic guy.
    Also moved to the correct section.
  3. #3 Re: Fuse Numbers??
    Houston
    The fuses in the glove box are not numbered. Only the ones under the hood are.
  4. #4 Re: Fuse Numbers??
    Aug 2012
    United States
    Which one would be the HVAC con fuse?
  5. #5 Re: Fuse Numbers??
    Aug 2012
    United States
    Thanks for the info! Just confirmed what I thought
  6. #6 Re: Fuse Numbers??
    Houston
    Hvac ctrl
  1. are these numbers right?
    By GenVI805 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2011, 09:16 AM
  2. what do you guys think of these numbers?
    By Poil336 in forum Off Topic Discussion
    Last Post: 02-16-2010, 08:12 AM
  3. Here are Tag Numbers.....
    By Roger B in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 03-24-2009, 02:43 PM
  4. Part numbers
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 01:50 PM
  5. Numbers
    By 04 GTP COMP G in forum Off Topic Discussion
    Last Post: 07-10-2008, 02:59 PM
