Thread: need a how to on replacing my radiator, 97 GT
Results 1 to 20 of 23
  1. #1 need a how to on replacing my radiator, 97 GT
    GT Level Member Mikey Bonefas's Avatar
    May 2012
    Waterloo, IA
    ive been searching for a how-to but i cant find one.
    if anybody has had to do this can yu give me some guidelines to follow,
    its my first time ever replacing one and Id like not to mess anything up.
    any help will help
  2. #2 Re: need a how to on replacing my radiator, 97 GT
    Remove dog bones and brackets.
    Remove upper rad hose.
    Unplug fans and unbolt them from rad, 3 bolts IIRC and unclip the trans lines at the bottom and wiggle it out past the rad.
    Remove lower rad hose and drain it, move it aside, unclip/bolt bolt trans cooler lines.
    Remove the 2 small brackets holding the rad in, then lift and wiggle the rad out and re-install.
  3. #3 Re: need a how to on replacing my radiator, 97 GT
    ^^That'll do it. It's pretty simple.
    Donating Users onetyme77's Avatar
    texas
    What is IIRC?
    Sent from my SCH-I535 using Tapatalk 2
  5. #5 Re: need a how to on replacing my radiator, 97 GT
    If I recall correctly.
    texas
    Thanks
  7. #7 Re: need a how to on replacing my radiator, 97 GT
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    you could remove the bumper cover and actual bumper if you wanted not 100% necessary but its not that hard
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  8. #8 Re: need a how to on replacing my radiator, 97 GT
    Why would you remove the bumper cover and bumper?
  9. #9 Re: need a how to on replacing my radiator, 97 GT
    Oct 2011
    Michigan
    easier access to the radiator
  10. #10 Re: need a how to on replacing my radiator, 97 GT
    Quote Originally Posted by asite57 View Post
    you've obviously never changed a radiator in a w body before
  11. #11 Re: need a how to on replacing my radiator, 97 GT
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Everything you need to touch for the radiator is on the motor side. You pull the front bumper and support off the only thing you'll run into is the AC condenser. Write up under initial question is spot on. It's easy, 20 minutes if that. Depending on where you live, you will want to be careful with the transmisison lines. I've come across ones that look brand new and other look like nuts off a Model T.. LOL Plenty of PB Blaster or Liquid Wrench and possibly boxed end wrenches to help make sure you don't round them off.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
    texas
    Quote Originally Posted by dbextreme View Post
    Thanks for the insight, gotta surely keep that in mind. Possibly getting a new radiator with in the next year. Any suggestions for a stock gp? Probably OEM replacement?
  13. #13 Re: need a how to on replacing my radiator, 97 GT
    May 2012
    Waterloo, IA
    well i ran into a delay with mine,
    went to put it in and realized that the connector for the overlow tank hose was busted off.
    so now im stuck with my clogged one until tommorrow.
    does anybody know if the buick century rads are better or the same? i can get one of those like $5 cheaper.
    just curious since i have to take mine back and swap it out anyways.
  14. #14 Re: need a how to on replacing my radiator, 97 GT
    St. Louis
    I actually just upgraded mine on my 00 GT to a 98 Monte Carlo rad w/ HD cooling. Instead of the stock 5/8" core on the GP now I have a 1 3/8" core and a larger built-in trans cooler to boot. Only needed to modify 2 things and it drops right in. I took pics and whatnot as I was going and plan on writing it up at some point.
    Cost of the radiator from OReillys was $135 or so.
    texas
    Quote Originally Posted by FordMan77 View Post
    Give a holler back on this thread when u do the write up
  16. #16 Re: need a how to on replacing my radiator, 97 GT
    May 2012
    Waterloo, IA
    what modifications did yu have to do?
    that sounds like something id like to upgrade to.
    but would it work with my 97? since it has the vacuum line trans?
  17. #17 Re: need a how to on replacing my radiator, 97 GT
    vacuum trans line has nothing to do with the radiator
  18. #18 Re: need a how to on replacing my radiator, 97 GT
    May 2012
    Waterloo, IA
    ok cool haha, wasnt sure so i figured id ask.
  19. #19 Re: need a how to on replacing my radiator, 97 GT
    St. Louis
    It will fit your 97. It only moves the fans back about 1/4", so it will still clear cars with headers as well from what I see. I had to buy a different lower rad hose to clear the belt/A/C compressor as the stock one has bends that put it a little closer than I'd like. I don't have the parts list here at work, so I'll update this when I get access to the info.
    The rad. I got from OReillys carries a lifetime warranty, and they had to order it and got it in a day. Part Number: 432387
    Make sure you take a tape measure with you when you pick it up and measure the top edge of the core to be sure they got the correct one, as there is also a 1" core available for this car. BTW the rad. is for a 1998 Monte Carlo with the 3800. Oreilly's show 3 rads avail. so be sure they send you the right one.
  20. #20 Re: need a how to on replacing my radiator, 97 GT
    St. Louis
    All, here is a link to the write-up I just created for this swap. Feel free to add USEFUL info as needed. Hope it helps.
    http://www.grandprixforums.net/radia...tml#post865651
  1. Replacing radiator
    By boothe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2012, 10:34 PM
  2. GTP radiator fit in GT?
    By dl1027 in forum General Tech Discussion
    Last Post: 09-25-2011, 10:08 AM
  3. radiator
    By blown gt in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-14-2010, 09:17 PM
  4. replacing the OEM radiator
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2008, 06:09 PM
