Thread: Some crate engine questions...
Results 1 to 11 of 11
  1. #1 Some crate engine questions...
    Top Swap in Progress bigtom9492's Avatar
    Dutchess county
    hey everyone,
    I've been looking for awhile and i just wanted some opinions.
    I have a basically stock 1999 gpgt. Intake that's it. the engine itself has 70k on it and the body 136k along with tranny and everything else. What im wondering is if i should get a crate engine from GM (or any other places you guys might recommend) or get a lower mile l67 from Ed Morad. I have plenty of money i have been saving so i can build my car the way i want it. What I'm wondering is how difficult is it to swap a l32 for a l67? can the trans be left in or should i get a 4t65e-hd ? The swap is being done by my buddy who is a mechanic for free, saved his life, long story. Any advise, criticism will be taken. Thanks!!
    Tom
  2. #2 Re: Some crate engine questions...
    new britain, ct
    70k is pretty low miles already, you should just top swap it and get headers. youll be better off than with an l67.
    07 Black GXP.
  3. #3 Re: Some crate engine questions...
    Charles City, IA
    my "new" short block had 120k when I built it.
    SMGPFC Two Nipple General
  4. #4 Re: Some crate engine questions...
    Waukesha, WI
    my crate engine haz 54k miles, it sitll smells new
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  5. #5 Re: Some crate engine questions...
    Grand Island, Nebraska
    Swap the whole motor in. The L32 has a different throttle body so you need to use the L67 one with an adapter plate. I think theres other things but I cant remember. At the very least just swap the L67 in.
  6. #6 Re: Some crate engine questions...
    GT Level Member dengnath's Avatar
    Jasper engines makes amazing engines for the price.... i think its probably 2400 for a new 3800
  7. #7 Re: Some crate engine questions...
    Aug 2012
    10768 Manning Avenue Court N, Grant Township, MN 55110
    While re-build costs are fairly comparable to costs of a crate engine, many engine builders require a core, and the core costs can be fairly high. If you do not have the same core this will add to the cost and might not make it as desirable as it can be.
    While I would probably be more of a 385 series fan, I am not too sure I would discount the idea of re-building the FE. This would dbe the easiest thing to do and probably the best bang for the buck.
  8. #8 Re: Some crate engine questions...
    St. Louis
    Quote Originally Posted by DavisClarke View Post
    You do realize we're speaking about a GM 3800 engine, not a Ford Big Block or FE series engine, right? 2 Totally different animals. Although I can't say I wouldn't like to see a 460 swap into a GP, lol... Torque for days.
  9. #9 Re: Some crate engine questions...
    Depending on how far you want to go. I'd hit up a rebuilt L32 instead of the L67 for the better rods etc. Likely the costs are nearly the same.
    Then if you get a long block, typically they come fully assembled without oil pan, without valve covers, without lower intake manifold and everything above that, without accessories etc.
    You'll end up needing a charger, harmonic balancer, throttle body, LIM, oil pan, you can use the accessory brackets, sensors, wiring off your motor, I'd suggest sticking with your transmission. Therefore you use the flex off your current motor. Change your diff to HD and passenger axle which would keep you in a 3.29 gear ratio, but with HD diff.
    That's most of what you'd need to make it happen. Then soem misc stuff like vacuum like etc.
  10. #10 Re: Some crate engine questions...
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    I have a spare 460 sitting on my engine stand, don't tempt me.. LMAO Turn my GP into a snow plow with all that extra weight up front!!!
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  11. #11 Re: Some crate engine questions...
    Feb 2009
    flintnasty MI
    Quote Originally Posted by dbextreme View Post
    it wouldnt be that much heavier... 40-60lbs more ish.
    car-part.com would probably have some 100k+ motor for around $500 and include a ton of spare parts like a blower, heads, etc... that you could part out.
  1. engine swap questions
    By chrisgsx in forum General Tech Discussion
    Last Post: 02-19-2011, 01:21 PM
  2. Engine Rebuild/ Sub questions
    By joliver2011 in forum General Tech Discussion
    Last Post: 11-22-2010, 07:44 PM
  3. Rebuild or crate engine
    By That Guy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2009, 11:12 PM
