Thread: Best Way to delete Straight pipes
Results 1 to 20 of 22
  1. #1 Best Way to delete Straight pipes
    GT Level Member Beelzeboul's Avatar
    Racine
    so like the topic says I had deleted mufflers when I first bought the car because they were blown. After that I enjoyed the sound of the car
    it was loud but still low pitch enough to not sound ricey.
    after installing headers which came with a straight pipe for cat the car is ridiculously loud and the backfires drive me insane.
    so whats the best way to get a little back pressure and some noise cancellation
    would a magnaflow HF cat do the trick for me?
    should I see about having two magnaflow mufflers installed instead?
    Thanx guys
    I'm sorry officer I didnt know I couldn't do that
  2. #2 Re: Best Way to delete Straight pipes
    Any of the items you've deleted will help with the loudness.
  3. #3 Re: Best Way to delete Straight pipes
    I live here. TLSheff's Avatar
    If you just have headers and completely straight pipe, I would suggest looking for a resonator of some kind (alot prefer a glasspack) and get a couple magnaflow mufflers and install them and see if you like it then
  4. #4 Re: Best Way to delete Straight pipes
  5. #5 Re: Best Way to delete Straight pipes
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Back pressure? Ha!
    GPONA #1 Cyber Bully
    Quote Originally Posted by blackspike2710 View Post
    Back pressure? Ha!
    Agreed.
    It can be quiet yet flow.
  7. #7 Re: Best Way to delete Straight pipes
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    I have borla and love it, but it is $$$
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  8. #8 Re: Best Way to delete Straight pipes
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Quote Originally Posted by Nickell View Post
    I also say go with Borla.
    You got an exhaust clip? Im thinking about buying Borla Pro XS, would like to hear what they sound like.
  9. #9 Re: Best Way to delete Straight pipes
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    Clips nickell CLIPS!!!!
  10. #10 Re: Best Way to delete Straight pipes
    Dec 2008
    Cedar Rapids, IA
    ill get a clip for you guys tomorrow morning.
  11. #11 Re: Best Way to delete Straight pipes
    a glass pack and what ever muffler you like.
  12. #12 Re: Best Way to delete Straight pipes
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    I don't even know if a cat will help with your raspyness you have now... I would put some sort of RES on it (normal one or a glasspack) and go from there. I'd be afraid that if you didn't like the sound of a glasspack that would be all you'd hear if you used it as a RES w/o mufflers. I had what the muffler called a "turbo tube" (fancy name they called their resonators) on my 90 GP and it toned my exhaust down a lot. It was about 18" long 5" round and it had three tubes in it to tone the exhaust down. It was not for sound really, but it gave the exhaust extra tubing to go through to calm down the muffler ping (raspy). It didn't do away with it 100%, but it helped A LOT.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  13. #13 Re: Best Way to delete Straight pipes
    the cat wont help quiet it at all really. so not really needed.
    id put a 30 inch glass pack (the longest one you can fit) the glass pack will help kill the drone. and a muffler/ mufflers of your choice. like i said before lol
  14. #14 Re: Best Way to delete Straight pipes
    I also put a 30" glasspack on my car and it sounded so much better after i was done with it.
  15. #15 Re: Best Way to delete Straight pipes
    i have a 32 lol its all about the length............
  16. #16 Re: Best Way to delete Straight pipes
    I put a 6 foot one on mine lol
  17. #17 Re: Best Way to delete Straight pipes
    Racine
    aight well I'll grab a glasspack and go from there I guess
    I actually like the way the car sounded with just the cat on it and mufflers gone hopefully that will get me back to my decibel range
  18. #18 Re: Best Way to delete Straight pipes
    Nov 2009
    Tennessee
    I think you just answered your question.... Get an magnaflow cat.
    I was assuming the cat wouldn't help much since it's not adding pipe for the exhaust to go through. It is creating back pressure though.
    Personally I would not buy anything without hearing video clips at least first... To each their own on sound. I personally wish I would have listened to more GP's before I impulse did what I did. I took the whole system off, bought a new downpipe (original broke at the flex point), then maganflow high flow cat, ubend delete, res delete, dumping into two blowmaster 40's I had sitting here... At idle my car sounds awesome, but that's about it. between 1500 - 2400 RPM's I have ping like a civic on crack. 2500 + it's not to bad when I'm on it, but I will NEVER take it on a long road trip because the drone at cruising speeds puts me to sleep. If I could go back, I would put two magnaflows on with some sort of RES to tone it down. Hell, if you want the best of both worlds, get you an electronic cut out, flip a switch and you have your open exhaust back.. I have one on my Firebird, LOVE IT!!!! LOL
  19. #19 Re: Best Way to delete Straight pipes
    Quote Originally Posted by dbextreme View Post
    a huge ass res/glass pack will help a ton with your drone.
    its never to late in install a 25 dollar part if you ask me.
  20. #20 Re: Best Way to delete Straight pipes
    Nov 2009
    Tennessee
    Oh I know... LOL I've just never gotten down to the muffler shop to do it.. I just like to ***** and whine about it!!!!
    If I had to do it again, and I didn't have emissions testing here I'd delete my rear O2 and put a cutout inplace of the cat keeping my stock catback... I like the looks I get in the Firebird when I open it up beside a ricer in traffic... LOL
  1. Straight pipes sound bad, loud ticking when accelerating
    By 2000 Grand Prix GT Blue in forum General Tech Discussion
    Last Post: 04-12-2012, 12:05 AM
  2. Down Pipes?
    By Pontiac Man in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-27-2011, 10:53 PM
  3. Dual Straight Pipes
    By pontgp02 in forum General Tech Discussion
    Last Post: 07-18-2011, 11:10 AM
  4. Stock exhaust, go straight to 3" stainless or do U bend delete first?
    By telkel2399 in forum General Tech Discussion
    Last Post: 12-07-2009, 09:12 AM
  5. Straight Pipes on GTP?
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2008, 08:12 PM
