Thread: Pump Noise on 1999 GTP
Results 1 to 20 of 26
  1. #1 Pump Noise on 1999 GTP
    SE Level Member Fireworks's Avatar
    Aug 2012
    Indiana
    I have a 1999 GTP and I've noticed that when I've been driving I'll hear (what I believe to be) pump noise, or something you would expect to hear from a servo. I have no idea what it could be and it happens while stopped, while driving, and no discernible pattern. It will turn on and it would be very hard to capture on video because it's a very subtle noise. If it happens to work later from my phone, I'll post it, however I don't have high hopes for that.
    It seems to be coming from the center of the car toward the front...I.E. anything mechanical in the front....
    Thanks in advance!
  2. #2 Re: Pump Noise on 1999 GTP
    Fuel pump should sound like it's coming from right behind the center of the back seat.
    Sarcastically I'll say center of the car toward the front, that's the engine. LOL Hey...you left that door open.
    Does the noise change or seem to be different during any driving conditions etc?
  3. #3 Re: Pump Noise on 1999 GTP
    Aug 2012
    Indiana
    It doesn't change during driving conditions. It is a noise that runs in spurts. It also will run for several seconds in 1 second bursts. Not sure how else to describe that lol
  4. #4 Re: Pump Noise on 1999 GTP
    this one is from left field, but hows you heat and a/c working?
    im thinking that maybe a blend door actuator is stuck on and cranking back and fourth on you maybe, as theres not much that has a electrical whine, aka servo sound up front, the actuators are dead center of the dash.
    d/s
    p/s
  5. #5 Re: Pump Noise on 1999 GTP
    May also be a evap purge soleniod or idle control.
  6. #6 Re: Pump Noise on 1999 GTP
    Aug 2012
    Indiana
    The a/c works great, haven't tried the heat yet and the idle is fine... Could it be some sort of coolant pump? I have a low coolant light on but figured it to be one of those GM gems. My car stays around 175-180 unless i sit in traffic then it hits 195
  7. #7 Re: Pump Noise on 1999 GTP
    You might want to check that coolant level. Most usually describe the sound by low coolant in the heater box as gurgling..but likely it's your noise.
  8. #8 Re: Pump Noise on 1999 GTP
    Aug 2012
    Indiana
    Coolant level was fine
  9. #9 Re: Pump Noise on 1999 GTP
    no coolant pumps, only the water pump on the engine.
    if the blend door was acting up you have warm or hot air on one side when using the a/c or cold air on one side when using heat.
    you temp sounds like its fine. they all go up and down like that. you could have a bad temp sensor for that or the low coolant sensor in the radiator is coated in mud from dex coolant over the years. either way its not good to let that go as those sensors do control your rad fans to some degree.
  10. #10 Re: Pump Noise on 1999 GTP
    It's fine in the overflow or the radiator?
  11. #11 Re: Pump Noise on 1999 GTP
    Aug 2012
    Indiana
    The climate control seems to work fine, don't think that's the issue.
    Yeah I figured the temp was fine but I'll prob need to replace the sensor. Those easy to replace? This is my first go around working on my own car. Took it to people before, but now cash reserves low and need to seek cheaper ways haha.
  12. #12 Re: Pump Noise on 1999 GTP
    Denver
    I think I know what he's referring to...
    I've also heard this, it sounds like it's coming from the dash. I though it was a the auto climate mixing servo (just a guess). It sounds like a cycling servo (like the tiny servo on a remote control car). It will cycle about 3-4 times intermittently and then stop. I've always wondered what this was, and I'm just guessing what it is. If that's what he's hearing, I'm pretty sure it's coming from the dash.
  13. #13 Re: Pump Noise on 1999 GTP
    Aug 2012
    Indiana
    The radiator and overflow are fine, neither seemed low.
  14. #14 Re: Pump Noise on 1999 GTP
    Seemed...as you you lifted the cap on the rad and looked in?
  15. #15 Re: Pump Noise on 1999 GTP
    Aug 2012
    Indiana
    Quote Originally Posted by SJAndrew View Post
    That's exactly the sound, I'll have to pay more attention to the climate mix now lol
  16. #16 Re: Pump Noise on 1999 GTP
    Aug 2012
    Indiana
    Yeah, one of the first things I did when I got the car earlier this month
  17. #17 Re: Pump Noise on 1999 GTP
    Ok, now I'm happy. Seemed like you were dodging the question based on being pretty sure it was full and not actually looking.
  18. #18 Re: Pump Noise on 1999 GTP
    Aug 2012
    Indiana
    Yeah, sorry. Just haven't checked it since then but I assume it's the same since the light was on then too
  19. #19 Re: Pump Noise on 1999 GTP
    this is where the temp sensor is.
    and the low coolant sensor is in the rad by the cap, under it, i forget witch side its on tho. remove, and clean this one before buying a new one.
  20. #20 Re: Pump Noise on 1999 GTP
    Might be worth double checking and finding out that it is full. I've solved a few problems by being a stickler on someone answering the actual question..lol
    You ... are the exception sir.
  1. 1999 GT with GTP Fuel Pump question
    By Higgins428 in forum General Tech Discussion
    Last Post: 05-18-2012, 06:41 PM
  2. Hissing noise, is it the fuel pump?
    By Frank217 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2012, 06:58 AM
  3. Hissing Noise On A 1999 Pontiac Grand Prix
    By GrandPrixChic in forum General Tech Discussion
    Last Post: 12-24-2010, 02:00 AM
  4. having problems removing water pump on 1999 grand prix gt 3.8L, series 2
    By RyanGerner in forum Introductions/Noob Questions
    Last Post: 08-17-2010, 09:30 PM
  5. Power steering pump noise
    By minichopper6hp in forum General Tech Discussion
    Last Post: 07-18-2009, 01:57 AM
