Thread: Cylinder 3 misfire Tried everything I can think of
Page 4 of 4 FirstFirst ... 234
Results 61 to 74 of 74
  1. #1 Re: Cylinder 3 misfire Tried everything I can think of
    -14 psi is impossible.
    MAP reads pressure, not air volume.
    And nothing reads air volume.
    Did you read my post at all or what?
  2. #2 Re: Cylinder 3 misfire Tried everything I can think of
    GT Level Member Beelzeboul's Avatar
    Racine
    yeah matt
    The parameters I'm looking at
    Intake Manifold Pressure labeled in PSI
    Mass Air Flow Rate in CFM
    the MAP is what I assume is giving me the IMP
    but I did indeed mean 14 not -14 sorry about that
    was thinking I was looking at my boost and had to reverse it to get vacuum...its been a kinda long day thanx for correcting me
    I'm sorry officer I didnt know I couldn't do that
  3. #3 Re: Cylinder 3 misfire Tried everything I can think of
    What scan tool are you using?
    MAF does not read volume. It reads air mass, hence name, Mass Air Flow sensor.
    14 PSI of boost is a bad sign unless you're running lots of mods and tiny pulley.
  4. #4 Re: Cylinder 3 misfire Tried everything I can think of
    Racine
    not 14psi of boost or vac matt
    my boost is around -10 at idle and than shoots up as I accelerate I have not gone WoT really so i dont know the total boost but I am getting positive right around the same time the car starts to miss
    4 psi intake manifold pressure spiking to 14 under half throttle
    been using my torque pro
    the MAF reading in cfm I have no idea about matt I just wanted to see if my numbers were where they should be stock and if one was off I was going to research that angle. what the numbers values are were kinda gibberish until your explanation here
    I'd link a pic if I could but its just a bar gauge that says MAF(cfm) with value underneath it
    at this point the values could lead me elsewhere but my misfire has moved since the new fuel pump it would not let me read the code but im getting a misfire count on cylinder 5
    so was going to check the components after engine cools. if all the components look good though I'm going to have to lean towards an air issue I know cylinder 3 and 5 run the leanest which was kinda my reasoning for checking my airflow and pressure numbers. it could be shooting me a misfire count on 5 and than a check engine light on 3 under a load but I wont know till it happens again and lets me read the code
  5. #5 Re: Cylinder 3 misfire Tried everything I can think of
    14 is not a valid number in PSI.
  6. #6 Re: Cylinder 3 misfire Tried everything I can think of
    Racine
    ok well than my only assumption would be that the value goes down as throttle increases and I'm ranging from 4 to -14
    scanning while driving is not the easiest for me especially trying to open up throttle in city so if I missed the negative sign while checking gauge it was probably cause I was busy missing the squirrel or child or random bicyclist
    not my intention to waste peoples time with impossible values ie mehbad
  7. #7 Re: Cylinder 3 misfire Tried everything I can think of
    Racine
    Ha ok so my scanner was recording my highest value and my current values so when I looked at my highest being 14.4 it was as the car shuts down
    from idle to about 2.5-3k hard to tell hand throttling motor my values range from 3.7psi to about 8psi max hope thats valid
  8. #8 Re: Cylinder 3 misfire Tried everything I can think of
    Apr 2009
    Fort Worth TX
    I've been following this thread and noticed that you have not mentioned trying to run the car in SD.
    So, does it miss when you run the car with the MAF unplugged?
    Please excuse me if you or the mechanic has already considered this.
  9. #9 Re: Cylinder 3 misfire Tried everything I can think of
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    Hey I was just wondering if you found the problem? I'm having a problem with cyl 2 and 3 missing but when revved up it stops.
  10. #10 Re: Cylinder 3 misfire Tried everything I can think of
    Racine
    It was a combination of a faulty coil pack injector and fuel pump BP was nice enough to reimburse me for all the parts and labor
  11. #11 Re: Cylinder 3 misfire Tried everything I can think of
    Dec 2011
    Decatur
    O alright cause having the same problem with no luck
    SE Level Member Scott Gerhart's Avatar
    Aug 2012
    Reading, PA
    I have this same problem. 2004 Grand Prix gt. cyl 3 misfire only at idle. No idea why
    The Boss Iceman6669's Avatar
    Jun 2011
    Quote Originally Posted by Beelzeboul View Post
    I have not seen you on here in a while..
    2011 F-150 Yote powered
  14. #14 Re: Cylinder 3 misfire Tried everything I can think of
    new york
    if you guys looked though the posts my car had the same problem. i used seafoam and the mystery oil every oil change and so far it has no more misfire which im assuming it was a sticking valve spring..
  1. Cylinder #3 misfire
    By Newby101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-15-2011, 03:02 PM
  2. Misfire in Cylinder 6
    By Porach in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2011, 02:19 AM
  3. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
