i have an 8rib MPS pulley and iirc stock is a 6rib belt my question is will my pulley work on my stock belt set up?
ok sweet i didnt know if it made a difference or not thanks
Well thats probably why mine is squeaking then. I have 3.8 ZZP pulley and a 3.4 Intense pulley and line them both up the same...
Which hub do you have?
IIRC Intense mps and pulley sits on inner most rib.
ZZP mps and pulley sit on middle ribs.
Keep in mind I just took some prescription cough medicine...and wow..this is good stuff.
I dont think so, ive had it off by 2 ribs before and it didnt move, but then again i put the stock belt on with a bigger idler pulley on the stock SC pulley so its kinda tight. And im not sure exactly which MPS i have, but i think its the intense one.
i have a 3.6" intense pulley i was going to use it with a zzp MPS hub and the stock length supercharger belt
I have succeeded in jacking this thread. And bill, those pictures dont help at all. I dont even know which one is which.
well will that set up work?
