Thread: 4th gear missfire
Results 1 to 11 of 11
  1. #1 4th gear missfire
    GTX Level Member Juanmiguel's Avatar
    Mexico
    The GTP is having missfires in cylinders 1 and 5 only when cruising at around 55mph in 4th gear, specially if going up hill. If you shift into 3rd it will go away and it does not missfire under any other type of acceleration, not even WOT.
    It does missfire in all cylinders while idling, but that I guess it's because of the cam.
    I think I've read about similar cases before here in the forums, but I can't find them right now. Anyone know why this may be happening?
  2. #2 Re: 4th gear missfire
    Typically it's ignition/tune up related. High load, low rpm in high gear. That's when the system works it's hardest.
  3. #3 Re: 4th gear missfire
    Mexico
    I see, the plugs are a couple of months old (AL104s). The wires have over a year maybe. I could try the wires first I guess.
  4. #4 Re: 4th gear missfire
    GT Level Member reesez's Avatar
    Aug 2012
    indiana
    my truck used to do that after i mushroomed an exhaust valve. would miss and jerk while in od. no other time. then if i put in drive it was fine.
  5. #5 Re: 4th gear missfire
    Quote Originally Posted by reesez View Post
    This is a 3800 though. Valve issues are not very common. Igntion/tune up is the most common cause of this type of stuff.
  6. #6 Re: 4th gear missfire
    Aug 2012
    indiana
    true, but i did read about chipped pistons and thought maybe id throw a personal experience in there. it was a v6 and auto. just saying.
  7. #7 Re: 4th gear missfire
    I thought you sold your gtp?
  8. #8 Re: 4th gear missfire
    Mexico
    I did, to a close friend. I still help him out with this kind of stuff.
  9. #9 Re: 4th gear missfire
    GT Level Member Tony Mendez's Avatar
    Aug 2012
    Somerset WI
    Have someone put the car in reverse and brake torque it while you spray the coils with a spray bottle of water and see if the misfire develops. If it does, you may have a cracked coil(s). My advise has always been to replace the coils and module as a unit, if within your budget.
    Mexico
    Thanks, I have a couple of spare wires to swap for the missfiring 1 and 5 cylinders. I will also try spraying the coils.
    Sent from my GT-S5830L using Tapatalk 2
  11. #11 Re: 4th gear missfire
    My only issue with throwing other motor experiences in is that the OP may end up going after that and wasting time/money/effort on something that is super uncommon with the motor he's working on. Like if someone had suggested a head gasket, it's so uncommon it's one of the last things you suggest/test for.
    I try to aim the person at the most common and constant issues. That's all. Didn't mean it in a bad way.
  1. missfire HELP!!
    By Will5600 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2014, 10:25 PM
  2. Missfire
    By Enzo354 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2011, 09:26 PM
  3. missfire cyl 6
    By chrisLB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-28-2011, 01:53 AM
  4. gtp missfire
    By mtz956 in forum General Tech Discussion
    Last Post: 12-24-2010, 10:58 AM
  5. 04 GTP missfire
    By dlemmen in forum General Tech Discussion
    Last Post: 07-07-2010, 09:29 PM
