Thread: Replacing Underhood Fuse Block
Results 1 to 4 of 4
  1. #1 Replacing Underhood Fuse Block
    Aug 2012
    Arizona
    Has anyone replaced an underhood fuse block? I need to do one on my daughter's 2006 Grand Prix. Daytime running light relay melted and melted fuse block also. I am having trouble finding anything on the Internet. Also any good suggestions on where to buy a replacement?
    SE Level Member Peirce1970's Avatar
    Myrtle beach, S.C.
    You can buy a replacement from Morad parts for $44. A new one will run you around $400
  3. #3 Re: Replacing Underhood Fuse Block
    IIRC it's much like the 97-03 where once you pop it off the fender, you pop the back cover off it and there are 3 or so 7mm bolts holding the harnesses to it. A few minutes and you should have it replaced.
  4. #4 Re: Replacing Underhood Fuse Block
    Aug 2012
    Arizona
    Thanks everyone. I removed it from the car last night as I had to get the actual part number off of it. You were correct...took 5 minutes. Also in contact with Morad Parts about replacement. I really appreciate your comments!!!
  1. 1990 GP Need electrical schematic -> 60A underhood Fuse
    By Scanner in forum General Tech Discussion
    Last Post: 09-04-2010, 08:05 AM
  2. fuse block ?
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2009, 01:09 AM
  3. 04 Grand Prix Fuse Block map
    By btempelman in forum General Tech Discussion
    Last Post: 03-15-2009, 03:38 PM
  4. 04 GP Fuse Block Map - Power Window Circuit Breaker
    Last Post: 03-15-2009, 12:24 PM
  5. Underhood fuse box
    By Sabrewings in forum General Tech Discussion
    Last Post: 09-21-2008, 06:46 PM
