Thread: Motor support?
Results 1 to 20 of 25
  1. #1 Re: Motor support?
    Denver
    You don't need to support the engine from above to change the oilpan. You can jack it up via the tranny pan (with a piece of wood on your jack so you don't dent the pan) - don't forget to disconnect the mounts.
    I don't think dropping the subframe really improves the access to the oilpan. The three biggest PITA bolts are the ones that hold the motor mount u-bracket to the side of the block. With the tranny connected to the bell-housing, there is about 2" of room to get a wrench in there. Expect about 30 min per bolt (you can rotate about 15* at a time, getting them tapped during reinstallation is 2x harder), lots of hand cramps, and lots of f-bombs.
    Once you get this bracket loose, it's relatively smooth sailing.
  1. Core Support
    By boothe in forum General Tech Discussion
    Last Post: 03-29-2012, 05:17 PM
  2. lumbar support
    By vincegpking in forum General Tech Discussion
    Last Post: 04-07-2011, 06:44 AM
  3. Needs some GPF support and votes!
    By Swash in forum Off Topic Discussion
    Last Post: 10-07-2010, 02:58 PM
  4. 2-support Mirrors
    By arc in forum 04+ Specifics
    Last Post: 02-08-2010, 02:42 PM
  5. Got A Dilema, Which Engine Support
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 06:03 PM
