Thread: got scanned, codes dont mean anything to me. help me out here
Results 1 to 8 of 8
  1. #1 got scanned, codes dont mean anything to me. help me out here
    GT Level Member Mikey Bonefas's Avatar
    May 2012
    Waterloo, IA
    ok so i took my car to Advance Auto the other day and got three codes.
    dont know what they mean, but maybe someone can help me understand them a little better.
    1st- P0118 eng coolant temp ckt high input
    2nd- P0135 o2s heater ckt malfunction 1/1
    3rd- P0441 evap cntrl system purge flow fault
    really could use the help.
  2. #2 Re: got scanned, codes dont mean anything to me. help me out here
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    sounds like u need a coolant temp sensor a o2 sensor and a purge valve
  3. #3 Re: got scanned, codes dont mean anything to me. help me out here
    May 2012
    Waterloo, IA
    well i unplugged the coolant sensor because i got tired of seeing low coolant when i had plenty in there. im getting a new radiator on friday/saturday. so hopefully i get one with that one that works. are the other two important?
  4. #4 Re: got scanned, codes dont mean anything to me. help me out here
    Coolant temp is a totally different sensor than coolant level.
    If you search on those codes here..you'll find a ton of good info.
  5. #5 Re: got scanned, codes dont mean anything to me. help me out here
    Apr 2009
    Elkhart
    Ya coolant temp is under the t stat and the heater in the front o2 sensor is out just needs a o2 now the purge can be a lot of evap but mine was a purge valve itself that was leaking under vac and caused that code
  6. #6 Re: got scanned, codes dont mean anything to me. help me out here
    May 2012
    Waterloo, IA
    hmm, well i tried lookin up the codes on here but i dont have any of the same symptoms everyone else had. my car runs fine. and my temp gauge never goes above 220. so im not sure whats needed. (getting my radiator friday)
  7. #7 Re: got scanned, codes dont mean anything to me. help me out here
    Apr 2009
    Elkhart
    dont know might just have a messed up input causing it to go to high at some times
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  8. #8 Re: got scanned, codes dont mean anything to me. help me out here
    Ok..well if you don't talk to us..then we don't understand what is happening. You said.. got these codes and don't understand them. I can google search and learn a ton about a code. Would assume that you would as well in trying to fix your issues. Then you say.. my issues aren't the same as others.. so far you've only told us you have codes...nothing else. We need more info from you to know what is happening at your end.
    We are pretty good at diagnosing things..but we aren't quite there on mind reading.
  1. Scanned my Car for codes today and..........
    By Mad GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2012, 06:29 PM
  2. so I kind of scanned my car.
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-31-2011, 10:13 PM
  3. Get the car scanned?
    By boosted97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-07-2010, 11:59 PM
  4. Scanned my car today.
    By JoshsGTP in forum General Tech Discussion
    Last Post: 09-15-2010, 11:59 AM
  5. Want to get my car scanned. Where? How?
    By 04CompG in forum General Tech Discussion
    Last Post: 03-20-2008, 10:17 AM
