Thread: sensor beside map senor has no vacuum line attached
Results 1 to 9 of 9
  1. #1 sensor beside map senor has no vacuum line attached
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
    on my 97 gtp the sensor on the left of the map sensor has an elbow for a line but no line. the factory boost gauge on the dic reads zero boost even when i am in boost so i am guessing thats the reason. anyone know which line goes into this sensor and where it connects to?
  2. #2 Re: sensor beside map senor has no vacuum line attached
    GT Level Member sugaryuk's Avatar
    vancouver,bc
    iirc-- it should run to a tee fitting under the s/c snout and from there it goes to your fuel press regulator.
    just reread your thread-- I thought you were talking about map sensor-- sensor beside it could be evap. Here's some help
    02 GT- L32/Gen V, 3.3 mps, zz 1.9's, N*, slp front to back, OverKilled, 180 tstat, 104's, K&N cai, lowered with GMMP susp, 12" PBR brakes
    75 Pro-Street Vega-- Blown 383 stroker with Nos fogger system
  3. #3 Re: sensor beside map senor has no vacuum line attached
    Houston
    If you're talking about the vacuum tree, the middle port goes to the HVAC inside of the car. I believe on 97's it should be capped off. The red line in the picture above ends up here (behind the center console, near the firewall, passenger side.)
  4. #4 Re: sensor beside map senor has no vacuum line attached
    Sep 2011
    Vancouver
    also, i was looking in my engine bay for a while and i think the evap was removed, cant see the canister anywhere
  5. #5 Re: sensor beside map senor has no vacuum line attached
    Sep 2011
    Vancouver
    it's a round-ish sensor on the left of the map.
  6. #6 Re: sensor beside map senor has no vacuum line attached
    vancouver,bc
    evap can on a 97 is located in the r/t rear wheel well
  7. #7 Re: sensor beside map senor has no vacuum line attached
    Sep 2011
    Vancouver
    well, whatever the elbow was supposed to go to, i blocked it off and took the car for a spin. boost gauge now works and the car drives much smoother, better throttle repsonse.
  8. #8 Re: sensor beside map senor has no vacuum line attached
    vancouver,bc
    sounds like the "vacuum leak fixed mod" ...one of the cheaper ones to do!
  9. #9 Re: sensor beside map senor has no vacuum line attached
    Sep 2011
    Vancouver
    yeah, no doubt haha
  1. Vacuum Line
    By sumdude in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2011, 03:05 PM
  2. Where is the vacuum line??
    By Bigbm80 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-27-2009, 01:04 AM
  3. vacuum line kit for 98 gtp?
    By Liquifire in forum General Tech Discussion
    Last Post: 11-09-2009, 09:49 AM
  4. Vacuum line
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:11 PM
  5. Vacuum line...where does it go
    By chrizzle17 in forum General Tech Discussion
    Last Post: 02-25-2009, 11:15 PM
