Thread: Where is the vacuum line??
Results 1 to 3 of 3
  1. #1 Where is the vacuum line??
    SE Level Member Bigbm80's Avatar
    Feb 2009
    Princeton NJ
    I am going to be putting seafoam in my car and I know 1/3 of the bottle goes if the vacuum line from the brake booster but I am unsure where that is located. Pictures would be great so i can see exactly where it is. I have also read that you can put it in the intake, I assume they mean the air intake, and I am unsure if that is such a good idea because I can easily do that because i can just take the filter off my cold air intake and pour it in that way.And if I do pour it in my intake than should I do it while its running? please help anyway you can thanks!
  2. #2 Re: Where is the vacuum line??
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    the vacuum line i used was the one coming out of the bottom of the brake booster (big black round thing on driver side firewall) just take the line off the booster and pour the seafoam in while the car's running. when you're at about 1/2 a can, stop pouring and let the car stall out. Put the vac line back on the booster. Then pour the other half of the can in the gas tank. Wait for 20minutes or so and then fire it up again (might crank a bit hard but don't worry its normal) wait for most of the smoke to clear out of the exhaust, then go and drive the piss out of it for 5-10 minutes. Done.
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  3. #3 Re: Where is the vacuum line??
    Donating Users kfish's Avatar
    Ohio
    leave the car run. and pull the line coming out of the brake booster. its the black round thing behind the master cylinder. easy way to put it is, its right in front of the steering wheel on the other side of the firewall. there will be a line on it. pull it out. car will start to run like crap, then you just stick in in the seafoam can and let it stuck it out.
  1. vacuum line kit for 98 gtp?
    By Liquifire in forum General Tech Discussion
    Last Post: 11-09-2009, 09:49 AM
  2. Vacuum line
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:11 PM
  3. TB vacuum line thing
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-24-2009, 06:54 AM
  4. Got pictures for my vacuum line where does it go
    By chrizzle17 in forum General Tech Discussion
    Last Post: 03-09-2009, 02:49 PM
  5. Vacuum line...where does it go
    Last Post: 02-25-2009, 11:15 PM
