Thread: Turn the key and everything dies
Results 1 to 7 of 7
  1. #1 Turn the key and everything dies
    Jul 2012
    United States
    So I've got a 98 Grand Prix GTP and when we go to start the car it does all the self checks then when we go for the actual turn over is where the problem starts. It maybe gets a crank going then all the electronics just die on us and we need to disconnect the battery and reconnect just to get the key out. So we're thinking it's either the battery or the terminals or the cables somewhere just any tips?
    Thanks in advance!
  2. #2 Re: Turn the key and everything dies
    St. Louis
    Yep, sounds like a loose connection somewhere, or a bad ground. Clean the battey terminals and cables and make sure they are tight when you reinstall them.
  3. #3 Re: Turn the key and everything dies
    or a dead battery. and like he said up there^^^^^
  4. #4 Re: Turn the key and everything dies
    St. Louis
    All you need is 1.21 Gigawatts and you're good to go!
  5. #5 Re: Turn the key and everything dies
    Jul 2012
    United States
    Well quick update I got it to start pass emissions and get my stickers and everything but now we are back at square one with the same issue. Turn the key clicks everything goes out and we need to fiddle with the battery terminals and it's a new battery, an interstate megatron. Somewhat fitting if I had to pick a side I'd say Grand Prix's are Decepticons. So maybe it's the leads? Or the wiring harness, which just thinking about that makes me shudder.
  6. #6 Re: Turn the key and everything dies
    if playing witht he battery cables make it work, then change both cables.
  7. #7 Re: Turn the key and everything dies
    agreed
  1. Regal dies when turn signal is on
    By 2000regalGS in forum Buick Regal
    Last Post: 08-20-2012, 05:43 PM
  2. 1998 GTP Won't Turn Over, Car Dies, Key stuck in ignition
    By Columbia in forum General Tech Discussion
    Last Post: 08-14-2012, 01:12 PM
  3. car dies when i turn on ac.
    By puffalot1977 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-05-2012, 04:07 PM
  4. High beams turn on intermittently when using turn signals
    By Boomersooner in forum General Tech Discussion
    Last Post: 01-13-2012, 08:31 PM
  5. Car dies when using turn signal
    By 4boostin in forum General Tech Discussion
    Last Post: 07-28-2010, 05:57 PM
