Thread: car dies when i turn on ac.
Results 1 to 9 of 9
  1. #1 car dies when i turn on ac.
    Mar 2012
    United States
    i have a 98 gt. last year the ac worked amazingly. this year when i turn it on it makes sum wat of a squeling sound and usually the car dies rite away. the compressor isnt locked up.
  2. #2 Re: car dies when i turn on ac.
    It might be locking up when you turn it on.
  3. #3 Re: car dies when i turn on ac.
    Mar 2012
    United States
    so do i need to change out the compressor??
  4. #4 Re: car dies when i turn on ac.
    Most likely but I'm not positive.
  5. #5 Re: car dies when i turn on ac.
    St. Louis
    Sounds like a bad compressor. It's putting such a load on the motor that it kills it. That squeal you hear is likely the compressor bearings seizing up and the belt slipping.
  6. #6 Re: car dies when i turn on ac.
    Mar 2012
    United States
    are they hard to change out??
  7. #7 Re: car dies when i turn on ac.
    They are super easy if the front manifold is out of the way lol. I've never done one any other way though so I'm not sure how bad it would be.
  8. #8 Re: car dies when i turn on ac.
    take the belt off to see if it stalls after you start it.
    if the clutch on the compressor is shot, just buy a new compressor. changing its not worth it in the long run.
    if you plan on doing this yourself, find a shop to vac out the a/c system for you, go home swap your compressor and its best to swap the orifice tube as well at the same time. take it back to the shop and re use your old R what ever it is that the shop has on hold for you. of course they will charge you to empty and refill your system but you know it was done right.
  9. #9 Re: car dies when i turn on ac.
    Mar 2012
    United States
    i noticed that when the compressor goes to kick on it makes a like hiss noise and does it when it kicks off. its not locked up to make the belt squel. but also noticed it sumtimes makes the gauges on dash go goofy and the trac control lite come on .
  1. Dont like to turn left but easy to turn right
    By Randall in forum General Tech Discussion
    Last Post: 02-01-2013, 12:11 PM
  2. Regal dies when turn signal is on
    By 2000regalGS in forum Buick Regal
    Last Post: 08-20-2012, 05:43 PM
  3. 1998 GTP Won't Turn Over, Car Dies, Key stuck in ignition
    By Columbia in forum General Tech Discussion
    Last Post: 08-14-2012, 01:12 PM
  4. High beams turn on intermittently when using turn signals
    By Boomersooner in forum General Tech Discussion
    Last Post: 01-13-2012, 08:31 PM
  5. Car dies when using turn signal
    By 4boostin in forum General Tech Discussion
    Last Post: 07-28-2010, 05:57 PM
