Thread: Extreme tire wear
Results 1 to 9 of 9
  1. #1 Extreme tire wear
    GT Level Member iRideGTP's Avatar
    Jul 2012
    California
    Any ideas to what made or is making this to my tire. i replaced the front passenger tire 4 months ago cuz it was just like this except a bit worse and yesterday i found out now its the same on the driver side. its in the inside of the tire about an inch of wear..looks almost like it was peeled. nothing seems to be rubbing against it and the passenger tire still looks great.alignment issue?
    Extreme tire wear Attached Images
  2. #2 Re: Extreme tire wear
    St. Louis
    Could be an alignment issue, or bad suspension part. I would def. get it to a shop and have it aligned. Chewing up tires in 4 months is not a good sign. Make sure they're properly inflated as well.
  3. #3 Re: Extreme tire wear
    Jack it up and make sure everything is tight.
    Jul 2012
    California
    ill jack it up and do the 9/3 and 12/6 oclock check. i bought my gp back in December and dont kno when was last time it was aligned so i will definitely get one done. wat are the specs for alignment?
  5. #5 Re: Extreme tire wear
    The alignment shop will know the alignment specs.
  6. #6 Re: Extreme tire wear
    Texas
    Looks like your a arm bushings and possibly your ball joint is fubared. It's a pretty straight forward install-4 bolts. Jut need a pickle fork to separate the ball joint.
    85 Corvette
    01 TA
    03 Z06
    Jul 2012
    California
    alright then. thanks for the help FordMan77 & dsmuts
  8. #8 Re: Extreme tire wear
    Quote Originally Posted by txslow6 View Post
    3 bolts
    Jul 2012
    California
    just finished checking for movement and nothing..all nice and tight. ill just change the tire and get the alignment done hopefully thats all it needs. Thanks for the help
  1. Tire wear on inside edges in back
    By nlinesk8s in forum Brakes/Suspension/Chassis
    Last Post: 07-04-2014, 11:43 AM
  2. Inner rear tire wear
    By TTalon in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2013, 01:13 PM
  3. Rear tire wear
    By heavy duty in forum General Tech Discussion
    Last Post: 01-26-2011, 12:23 AM
  4. Tire wear issue
    By tommygunz in forum Tires & Wheels
    Last Post: 08-13-2010, 08:07 AM
  5. tire wear
    By izup69 in forum General Tech Discussion
    Last Post: 10-13-2009, 06:28 PM
