Thread: tips on motor drop in
Results 1 to 5 of 5
  1. #1 tips on motor drop in
    GT Level Member Toms04compg's Avatar
    Michigan
    At this point ive got an issue .... Due to the position of the motor i have got 4 of the trans to motor bolts in but the motor is about 3/4 inch away from trans. My question is would it be safe to tighten the 4 bolts to draw the motor in? As the other side of motor the cradle is sitting on the mount very off.
    Jan 2009
    Tallahassee, FL
    That's what I did. Try to wiggle it as close as you can first, when you start to tighten the bolts just do a little at a time to spread the load on individual bolts so you don't strip one.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #3 Re: tips on motor drop in
    Michigan
    How did ou have your picker hooked up mines set kinda crooked im thinking about moving it towards the passenger side or something this is horrible
  4. #4 Re: tips on motor drop in
    Jan 2009
    Tallahassee, FL
    I had mine hooked up on two opposite corners of the motor. One of the dogbone mounts and the opposite corner.
    77 Morris Garage B
  5. #5 Re: tips on motor drop in
    As long as your converter is properly seated on the transmission stator support, you can definately pull it right in with the bolts. It's the way it's done.
  1. Blower fan wont turn off with motor running , stops with motor off
    By bosull in forum Introductions/Noob Questions
    Last Post: 04-20-2012, 07:32 PM
  2. Dual tips or trapezoid tips?
    By GTLGDP in forum Visual/Body Modifications
    Last Post: 01-19-2012, 11:42 PM
  3. Motor Drop
    By 98GTPON22s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2009, 06:19 PM
  4. Tips on dropping in a motor ?
    By Meemperor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2008, 04:52 PM
  5. Doing a pan drop tomorrow any tips?
    By alacran in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-08-2008, 05:48 PM
