Thread: Motor Drop
Results 1 to 12 of 12
  1. #1 Motor Drop
    SE Level Member 98GTPON22s's Avatar
    Jan 2009
    Lithonia GA
    which Way Is The Easiest To Take Out Engine And Trans From The Cradle Or Up Top With A Motor Hoist
    Dont Think Cause Its On 22s I Wont Race You
  2. #2 Re: Motor Drop
    up top with a cherry picker is easier. it is also easier to not take out the trans with the motor if you dont have to because you dont have to take the axles out or mess with any of the trans fluid lines.
  3. #3 Re: Motor Drop
    Jan 2009
    Lithonia GA
    Im Tryin To Pull Both Out Without Dropin The Cradle
  4. #4 Re: Motor Drop
    May 2008
    staten island,NY
    if youre pulling out both i would just drop the cradle. do you have a lift?
  5. #5 Re: Motor Drop
    Jan 2009
    Lithonia GA
    Quote Originally Posted by QwikGT View Post
    No Doing It By Hand
  6. #6 Re: Motor Drop
    TDCRacing
    Guest
    When i do it i just do them one at a time. Don't forget there is a bracket on the passenger side of the transmission that connects the engine to the tranny. So don't forget to take that off.
  7. #7 Re: Motor Drop
  8. #8 Re: Motor Drop
    Jan 2009
    Lithonia GA
    So Pulling Them From The Top Is Easier
  9. #9 Re: Motor Drop
    TDCRacing
    Guest
    Enless you have a lift yes.
  10. #10 Re: Motor Drop
    Jan 2009
    Lithonia GA
    no lift
  11. #11 Re: Motor Drop
    TDCRacing
    Guest
    yep then from the top.
  12. #12 Re: Motor Drop
    Jan 2009
    Lithonia GA
    Quote Originally Posted by TDCRacing View Post
    Ok Thanks
  1. How long does it take to drop a tranny?
    By ohgreatone32 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-04-2008, 01:38 PM
  2. possible to drop an L67 into a 2001 grand am gt?
    By GTX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2008, 11:29 AM
  3. Power drop!
    By YoungGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2008, 01:47 PM
  4. Doing a pan drop tomorrow any tips?
    By alacran in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-08-2008, 05:48 PM
  5. power drop
    By Toasty in forum General Tech Discussion
    Last Post: 03-18-2008, 07:36 PM
