Thread: help!
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: help!
    GT Level Member Toms04compg's Avatar
    Michigan
    Rico whats this milly lube stuff for the head bolts?... What does it do and should i remove bolts and use it?
  2. #22 Re: help!
    Apr 2009
    Fort Worth TX
    Molybdenum based engine assembly lubricant. You can get it at your local parts store.
    Warning: Don't put it on anything but bolts that require specific torque. If you put it on bearings it'll trash them.
    Yes, remove the bolts, lube and retorque to spec. Make sure to put a little on the underside of the bolt head where it comes in contact with the head.
  3. #23 Re: help!
    Or a dab on the head where the bolt goes...lol
  4. #24 Re: help!
    Apr 2009
    Fort Worth TX
    Nyah.....Wiseguy
  5. #25 Re: help!
    Michigan
    That sucks i wish there info on it before starting .... Smh ok hopefully the bolts are good still thanks.
  6. #26 Re: help!
    They are fine Tom.. listen to old man Chuck. He even knows how to use plastigauge.
  7. #27 Re: help!
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by Toms04compg View Post
    Dude, I know the bolts are still good if you're being honest that they have only been torqued to 37 ft-lb.
    If you torqued them all the way either don't remove them or go get new bolts and start over. It's that simple.
  8. #28 Re: help!
    Michigan
    Thanks guys and yes i only torqued one head to 37 ft lbs.
