Thread: help!
Results 1 to 20 of 28
  1. #1 help!
    GT Level Member Toms04compg's Avatar
    Michigan
    On an 04 gtp im doing a head gasket... 1st question from what i have read both head gasket arrows are to be towards the pulley side of motor?.... And second is the torque sequence they ask for 37ft lbs then a 120 degree from the 37ft lb point? Sorry just dont wanna screw up a fresh rebuild thanks fellers.
  2. #2 Re: help!
    Jan 2012
    Philadelphia
    yes both arrows should point towards the pulleys (front of the engine) not sure about the torque specs but are you using new head bolts? the old ones are one time use only
  3. #3 Re: help!
    Michigan
    Yes new head bolts what id did is torque to 37 ft lbs according to the sequence on this site.... Then if im understanding correctly from the 37 ft lb mark turn 120 degree from that point... I just need a little go ahead from anyone whos done these the right way... But good call though
  4. #4 Re: help!
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by Toms04compg View Post
    Make sure to put molly lube on the bolt threads and the underside of the bolt head...this is very important. Get them all tight (about 10 ft-lb) and go in sequence to 37 ft-lb. Use an angle gauge and go in sequence to get the 120 degrees.
  5. #5 Re: help!
    Mar 2012
    NC
    You are absolutely correct on the torque spec. Git R Done.
  6. #6 Re: help!
    Michigan
    Thats good news.
  7. #7 Re: help!
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    I would suggest not jumping to the 37ftlbs at first, step it up in stages. Just my $.02..
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  8. #8 Re: help!
    Maybe it was the S2 or that I had a 97 at the time. I recall the inner 4 bolts getting some additional torque. Anyone?
  9. #9 Re: help!
    Apr 2009
    Fort Worth TX
    Never heard of that. It's just a different torque spec for up to and including 98.
  10. #10 Re: help!
    Apr 2009
    Fort Worth TX
    Never heard of that Bill.
  11. #11 Re: help!
    K... likely an early production thing then.
  12. #12 Re: help!
    Apr 2009
    Fort Worth TX
    ...or Series 1?
  13. #13 Re: help!
    No Chuckie Cheese...my 97 Bville was a 97.
  14. #14 Re: help!
    Topeka, KS
    Chuckie Cheese lmao!
  15. #15 Re: help!
    found something
    Cylinder head bolts: 37 ft/lbs + 130 degrees + 30 degrees up to 10/98
    Yep... up to Oct of 98. Early production thing.
  16. #16 Re: help!
    Topeka, KS
    So take that chuckie cheese!
  17. #17 Re: help!
    Michigan
    No i didnt use any moly lube.... Is this a problem? I torqued to 37 but never did a 120 degree turn yet should i take them out?
  18. #18 Re: help!
    Apr 2009
    Fort Worth TX
    Pull them out and lube them if you haven't done the final angle.
  19. #19 Re: help!
    Michigan
    Hope i didnt waste a new gasket and bolts....
  20. #20 Re: help!
    Apr 2009
    Fort Worth TX
    Gasket doesn't care about the 37 ft-lb. It's the 120 degrees that smashes the helico flex. The bolts don't start to stretch until about 90 ft-lb.
