Thread: Flush/Drain Coolant from Bottom Radiator Hose
Results 1 to 4 of 4
  1. #1 Flush/Drain Coolant from Bottom Radiator Hose
    lexington ky
    I flushed and drained coolant from bottom Radiator Hose and was only able to get 4 quarts pure universal coolant and 1 quart 50/50 (4.5 equivalent quarts of coolant)with some spillage. I worked hard getting that in (ie. several bleed and burps). This included filling the overflow reservoir to the hot level. The system holds 12.3 quarts and based on my calculations I now have a .33 percent mix shy of the 50/50 mix recommended. Any explanations, comments or recommendations. It appears to run great at 180 degrees.
  2. #2 Re: Flush/Drain Coolant from Bottom Radiator Hose
    Denver
    your heater core is still full.
    You need to back flush to get all new coolant. This is what I use: Prestone® Flush N Fill Kit | Print View | Products | Prestone®
  3. #3 Re: Flush/Drain Coolant from Bottom Radiator Hose
    lexington ky
    It was backflushed using the flush fill kit.
  4. #4 Re: Flush/Drain Coolant from Bottom Radiator Hose
    Denver
    I just flushed mine and got 12 quarts into it.
  1. Radiator drain plug
    By bishdog25 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:40 PM
  2. Where is the drain plug located on my radiator
    By ls6velless454 in forum General Tech Discussion
    Last Post: 09-06-2010, 04:16 PM
  3. Radiator Flush
    By jrmnlm in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  4. radiator drain o-ring size? FAILED motormite drain.
    By alacran in forum General Tech Discussion
    Last Post: 04-03-2010, 08:16 PM
  5. Radiator Flush
    By keenan00gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2008, 09:29 PM
