Thread: Where is the drain plug located on my radiator
Results 1 to 3 of 3
  1. #1 Where is the drain plug located on my radiator
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    I have a 2000 GTP and I found an autozones website it's got the one that has the plastic wingnut thing that you can turn off by hand. I know on my car there's a drain plug that you have to put a 1/4 ratchet in but it is stripped. My question is where is the drain plug located on my radiator on my car if there are 2.
    There is no replacement for displacement........unless you have a supercharger or turbo
    2000 Bright Red GTP Coupe GXP axle back, GMPP sway bar, NGK TR6, 180 stat. (Uninstalled Aeroforce Interceptor, DHP PCM, FWI, Gen V on the way) and still no pulley in sight.
  2. #2 Re: Where is the drain plug located on my radiator
    Charles City, IA
    Just pull the lower hose. There is only the one drain.
    SMGPFC Two Nipple General
  3. #3 Re: Where is the drain plug located on my radiator
    the drain is small so its slow and it can easily become stripped.
    Lower rad hose is faster and can't be stripped.
  1. Radiator drain plug
    By bishdog25 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:40 PM
  2. radiator drain o-ring size? FAILED motormite drain.
    By alacran in forum General Tech Discussion
    Last Post: 04-03-2010, 08:16 PM
  3. help! - oil drain plug
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2010, 05:27 PM
  4. Special tool needed for radiator drain plug on 2000 GP?
    By halfwit in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-18-2009, 09:31 PM
  5. Hello...and where is my oil drain plug located?
    By mbable in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 12:18 PM
