Thread: Squeal from transmission or torque converter?
Results 1 to 6 of 6
Threaded View
overdrive Squeal from transmission or... 12-09-2010, 09:53 PM
andrewgp2000gt Re: Squeal from transmission... 12-09-2010, 10:10 PM
overdrive Re: Squeal from transmission... 12-09-2010, 10:25 PM
overdrive Re: Squeal from transmission... 12-09-2010, 10:49 PM
andrewgp2000gt Re: Squeal from transmission... 12-10-2010, 12:23 AM
tharrill Re: Squeal from transmission... 07-07-2012, 10:48 PM
  1. #1 Squeal from transmission or torque converter?
    Nov 2010
    Hannibal, MO
    First, some history on the car. I bought an '03 GP GT recently for my daughter. The car has 70k miles w/the 3.8 and the motor spun a rod bearing 9 days after we got it. The trans started slipping the same day. We got another 50k mile motor and trans from a salvage '02 GP and Trannyman95 graciously told me what parts I needed to swap in the transmissions to be able to use the '02 trans in the '03 car. This involved swapping the valve bodies, channel plates, pumps, internal wiring harnesses, and the internal shift linkages. To swap the linkages, you have to remove some of the clutch packs. I made the necessary trans changes Sunday, and I used the '02 torque converter, just because it had less miles. I finished putting the motor and trans in late last night, using 7.5 qts of Dexron III, and then drove it 2 miles and everything was great. I didn't drive it again until after work today and I went about 10 miles before I started hearing a high pitched squeal coming from under the hood. It only does it when there is no load on the trans. It'll squeal at any speed when coasting or idling in gear or in park. As soon as I give it just a little gas or if I'm going uphill with the cruise control on the noise goes away. When stopped, if I hold the brake pedal with the trans in gear and give it just a little gas, it goes away. I removed the drive belt on the motor and that didn't change anything. I shut it off for about 10 minutes, then started it and it took half a minute or so for the noise to come back. The fluid level looks good. Can this be the torque converter? Any ideas?
    Thanks.
    Dan
  1. New torque converter
    By dagger in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-16-2010, 07:39 AM
  2. Best Place to buy a torque converter
    By 2story in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-07-2009, 10:42 PM
  3. Torque converter ?
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-12-2009, 04:47 PM
  4. Torque Converter engagement
    By 98SilvermistGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-22-2008, 03:49 PM
  5. Quick Q: Torque Converter
    By TommyGloves in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-11-2008, 07:06 AM
