Thread: 2006 Grand Prix stalling issues
Results 1 to 11 of 11
  1. #1 2006 Grand Prix stalling issues
    Sep 2011
    Saint Joseph
    I've replaced the pedal sensor and swapped the throttle body, same problem. I'm all out of options other than wiring and ECM. I'm trying not to take it to the dealer. I need all the help I can get! Thanks.
    SE Level Member xBlacKxGTPx's Avatar
    springdale ar
    What is it doing?
    Sent from my HTC Sensation 4G using Tapatalk 2
  3. #3 Re: 2006 Grand Prix stalling issues
    Sep 2011
    Chicago
    Have you checked the CAT converter. A bad or plugged converter can cause stalling, mine did.
  4. #4 Re: 2006 Grand Prix stalling issues
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    What exactally is it doing? Stalling could be caused by anything from a bad sensor to problems in your transmission
  5. #5 Re: 2006 Grand Prix stalling issues
    More info on what exactly the car is doing.
    When does it stall, where in your drive period?
    As just a guess, the crank sensor is a known cause for random stalling.
  6. #6 Re: 2006 Grand Prix stalling issues
    Sep 2011
    Saint Joseph
    Won't rev with brake and gas applied at same time. 0-20 mph pedal has to be on the floor to move, won't go over 75 mph
  7. #7 Re: 2006 Grand Prix stalling issues
    sounds like a clogged cat, if you try to drive it at night, the cat will be glowing red in no time if its that clogged.
  8. #8 Re: 2006 Grand Prix stalling issues
    SWPA
    Could be a bad MAF
  9. #9 Re: 2006 Grand Prix stalling issues
    Jan 2012
    Indianapolis
    You can also check the cat conv. with a infared temp gun if you have one or can borrow one from someone. You have to wait until the engine is at opperating temperature and then check the temp right before and after the cat. It should read cooler on the inlet side and hotter on the outlet. If it is the same then the converter is not working but is not clogged either. If it is higher on the inlet side and lower on the outlet side then it is clogged.
  10. #10 Re: 2006 Grand Prix stalling issues
    Sep 2011
    Saint Joseph
    Chaffed wire on valve cover, was arcing. Finally fixed
  11. #11 Re: 2006 Grand Prix stalling issues
    Jan 2012
    Indianapolis
    Glad to hear
  1. 2006 Grand Prix Headlight Issues
    By Dre Man in forum General Tech Discussion
    Last Post: 02-08-2015, 07:52 AM
  2. my grand prix has been stalling out
    By dudek21 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 04:32 PM
  3. Acceleration issues 2006 Grand Prix
    By Natta in forum General Tech Discussion
    Last Post: 02-15-2012, 10:31 AM
  4. Stalling Grand Prix?
    By WPT289 in forum Introductions/Noob Questions
    Last Post: 05-24-2011, 05:59 PM
  5. 02 grand prix is stalling
    By some dude in forum General Tech Discussion
    Last Post: 01-28-2010, 03:59 PM
