Thread: Squeal from transmission or torque converter?
Results 1 to 6 of 6
  1. #1 Re: Squeal from transmission or torque converter?
    SE Level Member andrewgp2000gt's Avatar
    Apr 2009
    Illinois
    i know this sounds crazy spend the 2 dollars on a pcv valve and make sure u get the orings properly put back in i had this same issue and even had the trans diconnected and belt taken off and car started and still made the noise took a dealership to tell me a 35 dollar diognostic was a 35 cent oring fix.......no promise that its your issue but its worth a try especially with a salvage yard higher mileage engine its a cheap attempt
  2. #2 Re: Squeal from transmission or torque converter?
    Nov 2010
    Hannibal, MO
    That's not so crazy. I'll give it a try. I'm not sure at the moment which PCV valve I used, but the '02 motor has 50k miles and the car has 70k. That would be great if it's just the o-ring.
    Thanks.
    Dan
  3. #3 Re: Squeal from transmission or torque converter?
    Nov 2010
    Hannibal, MO
    You fixed it! That was it. Thank you sincerely! It's very much appreciated!
    Dan
  1. New torque converter
    By dagger in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-16-2010, 07:39 AM
  2. Best Place to buy a torque converter
    By 2story in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-07-2009, 10:42 PM
  3. Torque converter ?
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-12-2009, 04:47 PM
  4. Torque Converter engagement
    By 98SilvermistGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-22-2008, 03:49 PM
  5. Quick Q: Torque Converter
    By TommyGloves in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-11-2008, 07:06 AM
