Thread: Quick gasket question
Results 1 to 5 of 5
  1. #1 Quick gasket question
    GT Level Member Panzer4's Avatar
    Dec 2008
    Dubai, UAE/Camarillo, CA/New Delhi, India
    Hi guys,
    I have a 2000 GTP and I'm changing out the piston rings in my car and decided to change out all the gaskets as well. My problem is that here in Dubai parts are not that easily available (I would like to not order online because of time constraints) and the gasket kits available are only for GT N/A cars. Now I know that the supercharger gasket will be missing, but otherwise are the gaskets from a GT N/A car and a GTP compatible?
    If some gaskets are not, does anyone know which ones?
    Thanks in advance guys.
    EDIT: I should mention that I'm changing all the gaskets in the engine (what here they call upper and lower gasket kits).
    "Cry Havoc! And Let Slip the Dogs of War!"
    Black 2000 GTP: 3.4" Pulley, Resonator/U-bend delete, 180 T-stat, Tuned PCM, Thrasher Intake, Larger Radiator, 17" Konig Tantrum Wheels, Red Air Dams. Coming Soon...Projectors, Lighting Mods, Transmission Cooler, Black Rims, Tinted Tails and hopefully Headers
  2. #2 Re: Quick gasket question
    Jan 2012
    Philadelphia
    your talking about the head gasket right?
    im pretty sure the head gaskets are the same for S/C and N/A but im not positive
    i know you will need to get new head bolts because your not suppose to reuse your old ones because they are stretched from being torqued down
  3. #3 Re: Quick gasket question
    Dec 2008
    Thanks gtpeddie. Not just the head gaskets. I'm changing the head gaskets, water intake gaskets, valve stem seals, oil pan gasket, LIM gasket, fuel injector o rings all the way to...everything.
    Thanks for the input! Luckily the gasket kits are Felpro and come with the head bolts too so I'll make sure of that.
    Cheers dude!
  4. #4 Re: Quick gasket question
    Should all be the same. There's likely different listings...but the heads etc are the same except where the injector pocket is or isn't.
  5. #5 Re: Quick gasket question
    Dec 2008
    Glad to have your input Bill. Since you and gtpeddie pretty much said they would match I'm confident that this will work out properly. Thanks a lot again guys.
    If I find out anything to the contrary I'll post here again. Cheers!
  1. quick question
    By bmx6454 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-27-2012, 12:55 AM
  2. quick question
    By Jhorod09 in forum Off Topic Discussion
    Last Post: 03-11-2012, 07:58 PM
  3. silicone gasket need help quick...
    Last Post: 09-01-2009, 07:24 PM
  4. just a quick question
    By FtBll Coach in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-21-2009, 10:04 AM
  5. Quick PF question
    By BluFlameGTP in forum General Tech Discussion
    Last Post: 12-09-2008, 01:13 PM
