Thread: What is this part and which is broken?
Results 1 to 12 of 12
  1. #1 What is this part and which is broken?
    Jul 2012
    Hi,
    I apologize from the beginning because I know I don't know much but trying to figure out what the problem is before getting somebody else to look at it. I went to get my oil changed and when they were done, they said they could not move my car. When you press the brakes and attempt to move the shifter, it would be really loose and you couldn't feel the gears changing. Once in drive, it would not move at all. One of the men saw the problem and fixed it temporarily but couldn't tell me the name of the part or anything and couldn't tell me if it would cost a lot to fix. He said it wouldn't last and that the ball had fallen off? This is the piece:
    What I am unsure of is the bottom gray piece broken or is the top black piece? I can't tell and don't know much. Please if anyone could tell me the name of the broken piece and which is broken, it would be a lot of help.
    Thank you in advance!
  2. #2 Re: What is this part and which is broken?
    Jul 2012
    Grand rapids
    That's your shifter linkage it looks like the bushing is worn out
  3. #3 Re: What is this part and which is broken?
    Florida
    That is your shift linkage end piece thingy. Super scientific I know. Basically, when you shift gears inside, you physically move a cable, which pulls/pushes that black/yellowish end piece. When it moves, that silver plate with the ball on it physically moves, telling the tranny which gear to be in.
    It looks like, from the picture, that the end piece of the linkage is broken in the center (like a bushing of sorts) You'd need to replace that little end piece, and clip it back onto that silver ball, and you should be golden. It's fairly easy to get to, but Im not sure if that end piece is threaded in there, or not. If it's not, then you might end up having to fill that center area with some sort of filler, to take up the gap that's in there (though, that'd be a last ditch effort)
    Hopefully someone will chime in and let us know if that end piece threads on/off, and the exact name/part number it is.
  4. #4 Re: What is this part and which is broken?
    I live here. TLSheff's Avatar
    I can look up the part number to it, but I need to know what year it is and if its a base or GTP option.
    It is a shift cable definitely, usually the ends are NOT serviceable, you have to replace the whole cable. Not cheap either.
  5. #5 Re: What is this part and which is broken?
    Jul 2012
    It's a 2008 GXP V8. Well, today with a lot more light, I was able to get in there and play around a little bit. It is the bushing that is messed up. The white part in the picture. It is broken on one side, therefore it will come off the small ball really easily. I called the dealership today and they said the shift linkage has two parts, a cable and the end part that connects to the transmission?? I'm pretty sure all I need is the end part that connects but not sure now if the inside white part comes out (it appears as if it might) or which part exactly he was talking about. Whichever "end" part he was talking about, he said it was $50. I tried taking out the whole cable out by but it's connected at an angle and don't want to take things off to that so I just stopped playing with it.
  6. #6 Re: What is this part and which is broken?
    #19 is what you would be after, the $50.00 part. GM# 25940463 for it. Hope this helps some.
  7. #7 Re: What is this part and which is broken?
    $10 and a few minutes at any junkyard.
  8. #8 Re: What is this part and which is broken?
    Sep 2016
    Columbus, Ohio USA
    Hey guys I would like to let some people know that at the junkyard I found the part on a 2004 Buick Regal, and this part was exactly the same except the Black Plastic arm that that held the plastic Bushing is much better quality. This form helped me save over $200 thanks alot guys!
  9. #9 Re: What is this part and which is broken?
    Akron, Ohio
    Interesting this came back up. Mine just went. I am getting a new bushing from bushingfix for $25. Seems like a lot less work just to repalce the bushing than the whole cable.
    And boy is that cable long. I always wondered what that cable behind the headlight was. Who knew - it was for the transmission.
  10. #10 Re: What is this part and which is broken?
    hangover park IL
    The cable behind the headlight is for the hood latch the shifter cable has a service disconnect near the driver side strut Tower so that you only have to replace half of the shifter cable and not unbolt the center console of the car or feed it through the firewall
    ~James~ Psychotic Gearhead
  11. #11 Re: What is this part and which is broken?
    Sep 2016
    Columbus, Ohio USA
    Yes the bushing from BushingFix will work but be careful, if installed incorrectly, the bushing can cause the arm to slip when put in park.
    I almost bought one until my friend had to buy too and he got frustrated with spending $25 on a piece of plastic that broke during installation
    Just go to the junkyard!
    $15 got me going?
  12. #12 Re: What is this part and which is broken?
    Sep 2016
    Columbus, Ohio USA
    hey guys if you are REPLACING the cable, BE CAREFUL with theE Clip that holds the 2 cords together. It is easily breakable and is missing in this photo
  1. Old Thread
    By SpeedGrid in forum General Tech Discussion
    Last Post: 09-03-2012, 09:23 PM
  2. Car broken into help please
    By jteske88 in forum General Tech Discussion
    Last Post: 03-10-2011, 02:13 PM
  3. 2004+ Rear Seat Interior Light Switch Broken anyone find this part?
    By UCF04GPGTPCompG in forum Visual/Body Modifications
    Last Post: 02-27-2010, 01:39 PM
  4. someone explain what part is broken..maybe..
    By Bio248 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-17-2009, 10:22 PM
  5. HUD...Broken?
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 06-27-2008, 12:33 AM
