Thread: shuddering/wheel-hop in drive, not 1st or 2nd.
Results 1 to 6 of 6
  1. #1 shuddering/wheel-hop in drive, not 1st or 2nd.
    Denver
    I've been trying to find a shudder/wheel-hop when accelerating from stop.
    I've replaced pretty much every front-end suspension and powertrain component and the shudder (although less) is still there.
    I've replaced:
    - axles
    - LCA's
    - bj's
    - sway bar and bushings
    - struts
    - tires
    - motor and tranny mounts
    In my despair that now the axles and motor mounts have not fixed it, I'm resigned to wonder if it's the tranny.
    So, when I start from 1st, I get nothing but a smooth acceleration.
    Same with 2nd.
    In drive, I (sometimes) get a shuddering/wheel-hop.
    I just changed my tranny fluid. Nothing weird there (slightly brown but not that bad).
    Any ideas????
  2. #2 Re: shuddering/wheel-hop in drive, not 1st or 2nd.
    Wheel bearings?
  3. #3 Re: shuddering/wheel-hop in drive, not 1st or 2nd.
    Jul 2012
    Grand rapids
    Do you have your car lowered at all? I had some of those problems and thought it was axles nope it was the axle alignment I had to get shorter dog bones and pull the motor forward. Give it a shot before you replace your tranny.
  4. #4 Re: shuddering/wheel-hop in drive, not 1st or 2nd.
    St. Louis
    Drain a quart of trans fluid out and add a quart of Lucas stop slip. I'd be willing to bet this is torque converter shudder. When was the last time plugs and wires were put in it? Clean the MAF lately? A bad plug or wire could cause this under a load when the TC locks in 3rd and the MAF can cause all kinds of wierd sh*t, lol...
  5. #5 Re: shuddering/wheel-hop in drive, not 1st or 2nd.
    Thinking about this ....what changes from 1 or 2 into D. The only change is the engagement of the 2-1 manual band in addition to the already engaged forward band. Your forward band may be glazed, worn, or about to snap. Breaking is very common on our transmissions for original forward bands.
  6. #6 Re: shuddering/wheel-hop in drive, not 1st or 2nd.
    Denver
    This is definitely not an engine issue - it's a physical shuddering.
    Bill's explanation makes sense.
    I dropped the pan this weekend and changed the fluid. The fuild was fine, but the magnet had about 3/32" of metal dust stuck to it. It's the most I've seen before (especially considering the fluid was only about 14 months old).
    Bottom line: a replacement band is basically a tranny rebuild. What is the ROM cost for this?
  1. Rear Wheel drive
    By Whitehispanic in forum Brakes/Suspension/Chassis
    Last Post: 08-04-2011, 08:55 AM
  2. All Wheel Drive?
    By minichopper6hp in forum General Tech Discussion
    Last Post: 04-05-2009, 11:38 PM
  3. All Wheel Drive?
    Last Post: 04-05-2009, 09:41 PM
  4. Modded Audi 2.8 w/ All wheel drive
    By 99prixgt in forum Track Sessions and Kills
    Last Post: 11-12-2008, 04:18 AM
  5. Front wheel drive VS rear wheel drive.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 06-16-2008, 07:23 PM
