Thread: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
Results 1 to 20 of 23
  1. #1 Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    GT Level Member Adidasdude1989's Avatar
    Jan 2012
    Sturgis, MI
    I finally got around to replace my washer pump thinking thats the reason why my washer fluids didnt work and the fact that when i got the car, the person previously told me the pump was bad.
    Well i got the new one in, checked the hoses for any clogs (none), I blew into the electric connector, clearing any dirt and what not. Threw some water in the reservoir to test things out and nope, nothing happens. I tried 3 - 5 cycles, pushing any possible air through the hoses and still nothing works. Im frustrated and clueless.
    What else can i do? I hate cleaning my windshield from bug guts and other debris all the time.
    By the way, where would the fuse be for the pump?
    Miles: 170-XXX
    Engine: 3.8L V6
    http://youtube.com/KBsVlog
  2. #2 Re: Washer Fluid Not Pumping After Pump Replacement
    Jan 2012
    Philadelphia
    mine doesnt work either man i know how you feel i just removed my washer fluid reservoir
  3. #3 Re: Washer Fluid Not Pumping After Pump Replacement
    Jan 2012
    Sturgis, MI
    Im thinking im not getting any electrical current to the pump.
    Miles: 170-XXX
    Engine: 3.8L V6
  4. #4 Re: Washer Fluid Not Pumping After Pump Replacement
    Jun 2012
    Somewhere
    Mine turned out to be the multifunctional switch on the steering column 2001 GT. You will what to find a used on as they are high new!
  5. #5 Re: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    Jan 2012
    Sturgis, MI
    Added a photo about something strange.
    Miles: 170-XXX
    Engine: 3.8L V6
  6. #6 Re: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    Jun 2012
    Somewhere
    Tomorrow I will look were it plugs in at when I work on mine.
  7. #7 Re: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    Jan 2012
    Sturgis, MI
    Quote Originally Posted by vsixer View Post
    Alright cool, will be checking back at the post again
    Miles: 170-XXX
    Engine: 3.8L V6
  8. #8 Re: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    Any solution to this? I'm having the same problem. Replaced the pump, still no juice. And I really need washer fluid since I'm out driving between 1-6 AM every day. I'll don't want to have to hand wash my windows every day.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  9. #9 Re: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    Jan 2012
    Sturgis, MI
    Quote Originally Posted by Deezul_AwT View Post
    Nope, i still have no solution. Does the "low fluid" light turn on when you start your car like every other light? If not, you also probably have no power to the pump. vsixer never got back to me about the plug, nor have i been able to find a grand prix in my area to look at to find where this mysterious plug plugs into.
    Miles: 170-XXX
    Engine: 3.8L V6
  10. #10 Re: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    Feb 2008
    Cumming GA
    No, the low fluid light does not come on. I only disconnected one plug when I changed the motor, and the only other plug close to there is the one that runs to the low fluid gauge. I need to pick up a multimeter to see if I'm getting power there. No other electrical issues for me.
  11. #11 Re: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    Jan 2012
    Sturgis, MI
    What fuse would the pump run on? The wipers fuse maybe?
    Miles: 170-XXX
    Engine: 3.8L V6
  12. #12 Re: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    Feb 2008
    Cumming GA
    Quote Originally Posted by Adidasdude1989 View Post
    If it ran off the wiper fuse, then my wipers wouldn't work. But they run fine. I was kind of hoping it was that simple after replacing the motor, but no luck.
  13. #13 Re: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    Jun 2012
    Somewhere
    I haven't had time yet to work on my car to take pics. But I found the one above hope it helps. As far as no fluid, I had a car that after I checked the pump to make usre it worked, it ended up being the multifunctional switch on the column. Buy a used one as the are high new.
  14. #14 Re: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    Feb 2008
    Cumming GA
    Did your wipers still work, and only the pump was non functional? Did you buy it used from Morad or someone similar, or was it a junk yard find?
  15. #15 Re: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    Feb 2008
    Cumming GA
    Put an order in today with Morad for the multi function switch. $45 including shipping. Should be able to install it this weekend when I do my struts.
  16. #16 Re: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    Jun 2012
    Somewhere
    There is a torx head screw that is pointed straight at the steering wheel which is a pain. I just used a bit and a wrench that fit the bit to turn it.
  17. #17 Re: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    Feb 2008
    Cumming GA
    That's what the folks at Morad said - just use a bit and a wrench instead of the Torx head. They said it takes them 15, probably would take me 30. I can live with that, especially if it fixes the problem.
  18. #18 Re: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    Jan 2012
    Sturgis, MI
    Just confirmed that the plug in the photo above, has no relation to the wiper fluid. I just looked under the hood of another Grand Prix, the fluid in that 1 works with the plug unplugged so its not that.
    Miles: 170-XXX
    Engine: 3.8L V6
  19. #19 Re: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    Mar 2012
    Michigan
    can u rewire the pump to a push button switch mounted somewhere by your steering column? and then whem you press it only the pump would turn on the you would have to turn the factory switch to make the wipers turn on, correct?
    Honstly im cheap and i just want it to spray, dont care how lol
  20. #20 Re: Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    Quote Originally Posted by selym17 View Post
    that could be done real easy like. you just need to cut the wires at the plug, (leave 4 or 5 inches of wire on the plug end) and run the wires from the plugs pig tail to power and a a switch, do put a fuse on the power line.
  1. washer fluid not working
    By 2000gtp8410 in forum General Grand Prix Discussion
    Last Post: 01-14-2012, 05:01 PM
  2. Low Washer Fluid
    By ericrluoma in forum General Tech Discussion
    Last Post: 09-17-2009, 11:11 PM
  3. Windshield Washer Fluid
    By Pontiac99GTP in forum General Tech Discussion
    Last Post: 09-09-2009, 01:35 AM
  4. Fluid pumping out of vent
    By Progas in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-08-2009, 07:37 AM
  5. Washer Fluid Injection
    By 98GT3800 in forum General Tech Discussion
    Last Post: 10-21-2008, 11:51 AM
