Thread: Crankshaft Sensor Code Issues P0336
Results 1 to 5 of 5
  1. #1 Crankshaft Sensor Code Issues P0336
    Flint, MI
    2003 Grand Prix GTP running like crap. The OBD2 Code is P0336. I replaced the crankshaft sensor, to no avail. The RPM's fluctuate significantly & there is a lot of hesitation, it doesn't idle well and will occasionally stall.
  2. #2 Re: Crankshaft Sensor Code Issues P0336
    Manitoba, Canada
    my '98 gtp is scanning the exact same code... stalls when temp guage gets above the 1/4 hot level (i wait a few minutes and it will start/drive again, however, if you don't. wait long enough, it backfires and won't start).. i also lose my tach and my tcs light comes on (i presume i lose my traction control)...
    i bought a new crankshaft positioning sensor in hopes that that might be it.
    i haven't changed it out yet.
    any updates as to what your trouble was and how you fixed it?
    thanks.
  3. #3 Re: Crankshaft Sensor Code Issues P0336
    Quote Originally Posted by tboy160 View Post
    sounds like a big vac leak. get some carb cleaner and spray it around all your vac lines while the car is running, when the idle jumps up, you found you leak area.
  4. #4 Re: Crankshaft Sensor Code Issues P0336
    Flint, MI
    Mine turned out to be a faulty wire going to the Crankshaft Sensor.
  5. #5 Re: Crankshaft Sensor Code Issues P0336
    Manitoba, Canada
    this is what i did...
    http://www.grandprixforums.net/hello...tml#post921409
    seems to be good... only time will tell!
    tick-tock, tick-tock... phew! still good...
  1. crankshaft position sensor help
    By joshuasauce in forum Engine
    Last Post: 07-20-2021, 09:29 PM
  2. Code, p0336, tach quits and Traction control issue
    By jimtjr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-31-2012, 12:04 PM
  3. crankshaft sensor
    By sweetgtx98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-22-2011, 08:44 PM
  4. Threw crankshaft sensor
    By Sesleeper in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-06-2011, 02:29 PM
  5. bad crankshaft position sensor?
    By ChdMcD in forum General Tech Discussion
    Last Post: 08-13-2010, 01:06 PM
