Thread: Windows don't work
Results 1 to 7 of 7
  1. #1 Windows don't work
    Jun 2012
    south Carolina
    My wife drove our 1999 Grand Prix to the store, rolled down all 4 windows an inch to let the heat out, came out of the store 30 minutes later and none of the windows work. Any ideas?
  2. #2 Re: Windows don't work
    Apr 2009
    Fort Worth TX
    Check fuses?
  3. #3 Re: Windows don't work
    Jun 2012
    south Carolina
    There appears to be only one circuit breaker for the windows and my meter says it is fine.
  4. #4 Re: Windows don't work
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by r803 View Post
    Correct
    After looking at the schematics all windows draw power through the same 25amp breaker.
    Try replacing the breaker.
    If that's not it then there may be a short between the breaker and the motors.
    I'm sure all four motors wouldn't go bad at the same time.
  5. #5 Re: Windows don't work
    Apr 2009
    Fort Worth TX
    Do you have power on both sides of the fuse?
  6. #6 Re: Windows don't work
    Jun 2012
    south Carolina
    I did not check because (1) it is stinking hot outside and (2) it sounds like the motors in the front doors are running when I push the window switches. I will verify the power.
  7. #7 Re: Windows don't work
    Apr 2009
    Fort Worth TX
    Your should have mentioned that.
    Unplug the motors and measure resistance on power wires to chassis ground for each motor.
    Can you hear the rear motors running also?
  1. windows dont work well and im stumped
    By asite57 in forum General Tech Discussion
    Last Post: 04-15-2012, 05:54 AM
  2. did install on 05 gp, now windows don't work.
    By traksta15 in forum Audio, Security & Visual Electronics
    Last Post: 12-03-2011, 06:41 PM
  3. Windows work only when raining
    By aminkel in forum General Tech Discussion
    Last Post: 06-14-2011, 04:35 PM
  4. Windows and radio will not work
    By PatrolmanA16 in forum General Tech Discussion
    Last Post: 09-21-2009, 07:11 AM
  5. Rear windows intermittently work
    By 98GT3800 in forum General Tech Discussion
    Last Post: 11-20-2008, 07:33 PM
