Thread: windows dont work well and im stumped
Results 1 to 4 of 4
  1. #1 windows dont work well and im stumped
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    alright so the windows in my 2dr 99 GTP dont go up very well then always go down fine the passenger side works better if i reach across the car and use the switch on that door some times they wont make it up all the way if i shut the car off then wait a few min then turn it back on they can make it up one time the drivers side wouldnt go up so i poped out the switch, hit the back of it with a screw driver and it worked fine its so weird i dont know if its the window regulator or the master switch i know i need to lube up the window tracks, was just wondering what you all think thanks
  2. #2 Re: windows dont work well and im stumped
    Did you pull the switch apart and spray some electrical cleaner in the switch and see if it works better?
  3. #3 Re: windows dont work well and im stumped
    Oct 2011
    Michigan
    i did not but i will now do you think thatll work or should i buy a new switch?
  4. #4 Re: windows dont work well and im stumped
    It might work but if not I'd try a new switch
  1. did install on 05 gp, now windows don't work.
    By traksta15 in forum Audio, Security & Visual Electronics
    Last Post: 12-03-2011, 06:41 PM
  2. Windows work only when raining
    By aminkel in forum General Tech Discussion
    Last Post: 06-14-2011, 04:35 PM
  3. Radio,Sunroof,windows dont work
    By My GTP 97 in forum Audio, Security & Visual Electronics
    Last Post: 02-26-2010, 07:40 PM
  4. Windows and radio will not work
    By PatrolmanA16 in forum General Tech Discussion
    Last Post: 09-21-2009, 07:11 AM
  5. Rear windows intermittently work
    By 98GT3800 in forum General Tech Discussion
    Last Post: 11-20-2008, 07:33 PM
